Hi, i have this error when i try to compile my project. I think it is a problem with the basicLinearAlgebra library but i don't understand why i get this error as the library is in my documents and it seems it refereces to the right library...
Did you slavishly follow any examples to see how the library works (and that it does indeed work) before you attempted your own sketch?
I don't recognize the syntax, but the example I found included
// All the functions in BasicLinearAlgebra are wrapped up inside the namespace BLA, so specify that we're using it like
// so:
using namespace BLA;
which seems to be key.
When you share code or error messages, text is preferred to screen shots. Put it within code tags, one way is to use the <CODE/> button in the message composition window toolbar and do as it says
Please post your sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Please also post the full error message, again using code tags. As you will have see, the IDE has a button that will allow the full error message to be posted
#include "state_estimator.h"
void PredictionUpdate(const Matrix<1> &u, Matrix<1> &xhat) {
// UNCOMMENT AND COMPLETE LINES BELOW TO IMPLEMENT PredictionUpdate OF THE STATE ESTIMATOR
float Ts = 0.01;
float rw = 0.032;
// // System A&B-matrix
float arrayA[1][1]{{ 1 }}; //Provide here the element values of state-space matrix A
Matrix<1,1> A = arrayA;
float arrayB[1][1]{{ Ts*rw }}; //Provide here the element values of state-space matrix B
Matrix<1,1> B = arrayB;
// // Evaluate discrete-time system dynamics
xhat = A*xhat + B*u;
void CorrectionUpdate(const Matrix<1> &y, Matrix<1> &xhat, Matrix<1> &nu) {
// UNCOMMENT AND COMPLETE LINES BELOW TO IMPLEMENT CorrectionUpdate OF THE STATE ESTIMATOR
// // System C-matrix - measurement equation
float arrayC[1][1]{{ -1 }}; //Provide here the element values of state-space matrix C
// Matrix<1,1> C = arrayC;
// // Compute innovation
nu = y - C*xhat;
// // Set estimator gain
Matrix<1,1> L = -0.618;
// // Compute corrected system state estimate
xhat += L * nu;
#ifndef SE_SF_H
#define SE_SF_H
#include <BasicLinearAlgebra.h>
#include "mecotron.h" // Include MECOTRON header
void PredictionUpdate(const Matrix<1> &u, Matrix<1> &xhat);
void CorrectionUpdate(const Matrix<1> &y, Matrix<1> &xhat, Matrix<1> &nu);
#endif // SE_SF_H
This is the entire sketck. we got it from our professor so i presume the second part should be workign that's why i didn't add the BLA line,which i saw online too. The first part (.cpp part ) i wrote some lines but not that much. We had to add some results but not much. When i add the BLA line it gives me an error in the Matrix<1,1> = arrayA part
