using arduino IDE 2.0.4
flashing board nodemcuv2, core esp8266
on win10-64 (new pc)
even without and with ZADIG (to provide xtra ser, port)
I noticed numerous topics which all seem to have come to halt on this forum
The error kills me and forces to look for a better environment to work with unlesss somone can help me out
Hi @twillert. I'm sorry that you're having a problem compiling. I'm going to ask you to post some additional information that might help us to identify the problem.
NOTE: These instructions will not solve the problem. They are only intended to gather more information which might provide a clue that eventually leads to a solution.
Please do this:
- Select File > Preferences from the Arduino IDE menus.
- Check the box next to "Show verbose output during: ☐ compilation".
- Click the OK button.
- Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the COPY ERROR MESSAGES button on that notification.
- Open a forum reply here by clicking the Reply button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the compilation output into the code block. - Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txtformat. - Open a forum reply here by clicking the Reply button.
- Click the "Upload" icon (
) on the post composer toolbar:
- Select the
.txtfile you saved. - Click the Open button.
- Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
type or paste code hereUsing board 'nodemcuv2' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "C:\\Users\\Administrator\\AppData\\Local\\Programs\\Arduino IDE\\resources\\app\\node_modules\\arduino-ide-extension\\build" 10607 "C:\\Users\\Administrator\\AppData\\Local\\Temp\\arduino\\sketches\\691EE7144E1449CD7B73DF7AA17C87D3" "C:\\Users\\Administrator\\AppData\\Local\\Temp\\arduino\\sketches\\691EE7144E1449CD7B73DF7AA17C87D3/core/build.opt" "D:\\Arduino\\Blink/Blink.ino.globals.h" "C:\\Users\\Administrator\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding: cp1252
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'D:\Arduino\Blink\Blink.ino.globals.h' does not exist.
Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
read ECONNRESET
Compilation error: read ECONNRESET
would this be a hint to the cause of my problem
Tool arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7 already installed
Tool arduino:avrdude@6.3.0-arduino17 already installed
Tool arduino:arduinoOTA@1.3.0 already installed
Downloading packages
arduino:avr@1.8.6
Replacing platform arduino:avr@1.8.3 with arduino:avr@1.8.6
Uninstalling arduino:avr@1.8.3
Error upgrading platform: arduino:avr@1.8.3 is not managed by package manager
Uninstalling arduino:avr@1.8.6
Platform arduino:avr@1.8.6 uninstalled
Failed to install platform: arduino:avr.
Error: 13 INTERNAL: Cannot upgrade platform: arduino:avr@1.8.3 is not managed by package manager
