Compilation Error: Undefined reference to main
c:/users/mdmee/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
This is my code, literally the default blink example:
#include <Arduino_BuiltIn.h>
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
Welcome to the forum
Which Arduino board are you using and which board have you got selected in the IDE ?
Hi @meeran
welcome to the arduino-Forum.
Well done to post the error-message and the code as a code-section.
You should provide much more detailed information about the compile-process.
Read this 3 minutes tutorial to learn how to adjust the Arduino-IDE to automatically create alls the detail-information
Using Arduino UNO and thats the one selected in the IDE
That is not the default Blink example
Comment out that first #include
If I select Arduino Uno in my IDE and compile your code as posted in post #1
it does compile.
So there must be something else wrong.
You can now waste hours, days and weeks by posting too short new postings or take a single time 5 minutes to read and then follow this tutorial.
This will
AUTOMATICALLY
create all the details that you do not know yet to analyse to find the error
Your compile error is in the AVR boards code. Either your install went bad, or a HDD soft fail. In either case just do a re-install of the IDE. If this persists, you need to delete the entire Arduin15 folder and any other hidden Arduino folders (at least one)
Already tried
alright ill do this
These are all the details
FQBN: arduino:avr:uno
Using board 'uno' from platform in folder: C:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\mdmee\AppData\Local\arduino\sketches\72692CF9A2E9E385C9B7228DC9D46C74\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\mdmee\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\standard C:\Users\mdmee\AppData\Local\arduino\sketches\72692CF9A2E9E385C9B7228DC9D46C74\sketch\Blink.ino.cpp -o C:\Users\mdmee\AppData\Local\Temp\1600574688\sketch_merged.cpp
C:\Users\mdmee\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\mdmee\AppData\Local\Temp\1600574688\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\mdmee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\mdmee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\mdmee\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74\\sketch\\Blink.ino.cpp" -o "C:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\mdmee\AppData\Local\arduino\cores\arduino_avr_uno_566c47d9f63672ddb7f5ae3fcfffff35\core.a
Linking everything together...
"C:\\Users\\mdmee\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74/Blink.ino.elf" "C:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74\\sketch\\Blink.ino.cpp.o" "C:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74/..\\..\\cores\\arduino_avr_uno_566c47d9f63672ddb7f5ae3fcfffff35\\core.a" "-LC:\\Users\\mdmee\\AppData\\Local\\arduino\\sketches\\72692CF9A2E9E385C9B7228DC9D46C74" -lm
exit status 1
