Compile Error of Timer0 Overflow Vector with Arduino UNO (ATmega328P) and IDE
I am trying to use Timer 0 Overflow Interrupt in Arduino UNO (CPU = ATmega328P) and IDE. I wrote its code at a code block section below in this post but had a compile error as:
Linking everything together...
"C:\Program Files\arduino-1.8.19\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\xxxxx\AppData\Local\Temp\arduino_build_241054/Interrupt_Timer_TIMER0_OVF.ino.elf" "C:\Users\xxxxx\AppData\Local\Temp\arduino_build_241054\sketch\Interrupt_Timer_TIMER0_OVF.ino.cpp.o" "C:\Users\xxxxx\AppData\Local\Temp\arduino_build_241054/core\core.a" "-LC:\Users\xxxxx\AppData\Local\Temp\arduino_build_241054" -lm
wiring.c.o (symbol from plugin): In function `__vector_16':
(.text+0x0): multiple definition of `__vector_16'
C:\Users\xxxxx\AppData\Local\Temp\arduino_build_241054\sketch\Interrupt_Timer_TIMER0_OVF.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
The error disappears if I remove "ISR(TIMER0_OVF_vect)" section.
The error seems to be "multiple definition of `__vector_16'."
When I used TIMER2, its overflow interrupt code could be compiled and operation worked.
How can I solve this?
Please advise.
#include <avr/io.h>
#include <avr/interrupt.h>
  PORTB ^= (1<<PB5);
void Timer0_Init(void)
  TCCR0A = (0<<COM0A1)|(0<<COM0A0)|(0<<COM0B1)|(0<<COM0B0)|(0<<WGM01)|(0<<WGM00);
  TCCR0B = (0<<FOC0A)|(0<<FOC0B)|(0<<WGM02)|(0<<CS02)|(1<<CS01)|(0<<CS00);
  TIMSK0 = (0<<OCIE0B)|(0<<OCIE0A)|(1<<TOIE0);
  Timer0_Init();
  DDRB = (1<<PB5);
  sei();
  while(true) {
Timer 0 is used by the Arduino system for the millis() function. That means the overflow ISR for timer 0 is already in use.
MicroBahner,
Thank you for your prompt answer. Now I could understand why it is.
You could have looked for yourself
