Hello,
i am playing around with the timers of the arduino uno board, and noticed that timer0-ovf doesn't compile.
what is the reason for that??
See code attached:
Thanks for the info .....
Timer_8bits_16bits_interrupt.ino (1.59 KB)
Hello,
See code attached:
It compiles. It doesn't link, because TIMER0_OVF_vect (note spelling) is already used by the micros() and millis() library.
how can i make it run??
Change your loop function to be:
int main ()
setup ();
// do other stuff here
Now it doesn't call init() and thus doesn't initialize the timers, and now it compiles. Be aware that you won't be able to use millis(), micros(), delay() etc.
I don't see where you are using Timer 2. Why not use Timer 2 instead of Timer 0, then you won't have these problems.
boolean updown;
boolean onoff0;
They should be declared volatile, by the way.
Nice trick
thanks
Is the program will run faster if we use int main () instead setup and loop.
I thought that if we do not use millis, micros, delay in sketch, ISR(TIMER0_OVF_vect) is not busy, and the controller does not waste time to increase millis and micros?
Yes, it would save spending around 4µS x 1000 per second (say, 4 mS per second) by doing that.
I wouldn't call it a "waste" to keep track of time. Still, if you don't need it you don't have to. Or, you could just stop the timer.
