Hello All,
I am having a strange issue when compiling now. Never had such problems before ( for some years now ) and can't make the connection to any event that I remember to justify the malfunction.
I use Windows 7 64bit in a I7 computer. I installed the 1.8.13 IDE with the installer and also with the zip. Tried to compile the simplest ino ( default ino in the first time ) and get the following error:
Arduino: 1.8.7 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\arduino-1.8.7\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.7\hardware -hardware C:\Users\CALVIN\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.7\tools-builder -tools C:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\CALVIN\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.7\libraries -libraries C:\Users\CALVIN\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448 -warnings=none -build-cache C:\Users\CALVIN\AppData\Local\Temp\arduino_cache_924122 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\CALVIN\AppData\Local\Temp\untitled1201961831.tmp\sketch_mar27a\sketch_mar27a.ino
C:\arduino-1.8.7\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.7\hardware -hardware C:\Users\CALVIN\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.7\tools-builder -tools C:\arduino-1.8.7\hardware\tools\avr -tools C:\Users\CALVIN\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.7\libraries -libraries C:\Users\CALVIN\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10807 -build-path C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448 -warnings=none -build-cache C:\Users\CALVIN\AppData\Local\Temp\arduino_cache_924122 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\CALVIN\AppData\Local\Temp\untitled1201961831.tmp\sketch_mar27a\sketch_mar27a.ino
Using board 'mega' from platform in folder: C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\mega" "C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448\sketch\sketch_mar27a.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448\sketch\sketch_mar27a.ino.cpp
Generating function prototypes...
"C:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10807 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\CALVIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\mega" "C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448\sketch\sketch_mar27a.ino.cpp" -o "C:\Users\CALVIN\AppData\Local\Temp\arduino_build_547448\preproc\ctags_target_for_gcc_minus_e.cpp"
avr-g++: error: device-specs/specs-atmega2560: No such file or directory
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
I tried with older version of the IDE ( 1.8.10 and 1.8.7 ) and the same result.
I tried in my doughter laptop and it worked in the first time. She has the Windows 10 but . . .
I tried to delete Arduino15 folder and switch off the Antivirus but the result is the same.
I am out of solutions. It seams that the IDE looks for something that
I would apreciate some help
Thanks
