compile error using PROGMEM
PROGMEM string demo
How to store a table of strings in program memory (flash),
and retrieve them.
Information copied from:
http://www.nongnu.org/avr-libc/user-manual/pgmspace.html
const char string_0[] PROGMEM = "String 0";
// I get a compile error: variable 'string_table' must be const in order to
// put in read-only section by means of 'attribute((progmem))'.
// But it is defined 'const'!!!
const char *string_table[] PROGMEM = {
string_0
char buffer[30];
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[0])));
Serial.println(buffer);
// The full code was copied verbatim and failed to compile.
// This version is stripped down for examination.
Use code tags when posting code. Edit your post and add
[code]before the code and [/code]
after the code.
Some additional information is, in general, highly appreciated :wink:
2)
Please post the errors that you get.
3)
Please let us know version of the IDE and the board that you use.
Thanks, Delta_G. The extra const worked. Someone needs to update the sample code in the Arduino Playground - PROGMEM. Also, the avr-libc/user-manual.
Done.
Beauty of a wiki, everybody can do that :wink:
BTW, there's no reason to copy it to a buffer:
const char * const string_table[] PROGMEM = {
  string_0
  Serial.begin( 9600 );
  Serial.println( (const __FlashStringHelper *) pgm_read_ptr(&string_table[0]) );
void loop() {}
Casting it to the FlashStringHelper type selects the method that prints the bytes directly from flash.
;D Thanks -dev, another jewel of information from the Forum. I will give it a try.
