Compile error with arduino keypad "Event listener"
I have created the function:
void Keypad_apiClass::createKeypadventHandler(void)
keypad44.addEventListener(screenState_keyHandler);
which will be called in the setup() of my main sketch.
The eventlistener is also defined:
void screenState_keyHandler(KeypadEvent keyPressed)
switch(Display_api.screenDisplayID)
case 0x0A: //menu screen
switch(keyPressed)
case '1':
//go to sensor readings screen
case '2':
//go to system settings screen
case '#':
//go to systemReboot screen
default:
//do nothing
default:
And finally, in the header file, i have the class declaration:
class Keypad_apiClass
protected:
public:
void init();
char retrieveKeyPressed(void);
char waitAndRetrieveKeyPressed(void);
uint8_t returnKeyPressed_IntVersion(char keyPressed);
void createKeypadventHandler(void);
void screenState_keyHandler(KeypadEvent keyPressed);
I keep getting this compile error:
Compiling 'adutoSecuritySystem' for 'Arduino Mega w/ ATmega2560 (Mega 2560)'
keypad_api.cpp:In member function 'void Keypad_apiClass::createKeypadventHandler()'
keypad_api.cpp:112:50: error: no matching function for call to 'Keypad::addEventListener()'
keypad_api.cpp:candidate is
Keypad.h:addEventListener(void ()(char))
Keypad.h:no known conversion for argument 1 from '' to 'void (
)(char)'
Error compiling
It would seem that the addEventListener is not accepting the type of "screenState_keyHandler".
I'm not sure how to fix this.
Any help will be appreciated. Thanks. :slight_smile:
First...why does NOBODY every put there code in code tags?!?!?!
Yay code tags, click the </> button
Second...where is the class KeypadEvent?
Thanks for the quick reply :slight_smile:
It's my first time using the forum.
KeypadEvent is not a class, it's actually a typedef, which can be seen in the keypad.h library:
 typedef char KeypadEvent;
This is the eventListener function declaration:
The "screenState_keyHandler" is defined:
      switch(keyPressed)
         case '1':
         case '2':
         case '#':
         default:
         //do nothing
      default:
And of course, the function prototype is included in the corresponding header file:
 protected:
 public:
   void init();
And here's the compile error:
keypad_api.cpp:112:50: error: no matching function for call to 'Keypad::addEventListener(<unresolved overloaded function type>)'
Keypad.h:addEventListener(void (*)(char))
Keypad.h:no known conversion for argument 1 from '<unresolved overloaded function type>' to 'void (*)(char)'
Error compiling
I can see that the addEventListener accepts functions of type "void (*)(char) " as the parameter.
So where in my code do I have to fix this?
First, shouldn't createKeypadventHandler(void); be spelled with "Event"?
Second, please include the "keypad.h" file, because addEventListener isnt declared anywhere in the included files.
Thirdly,
you use screenState_keyHandler function as a parameter...but...
it has a parameter...
I'm not amazing a programming, but I'm pretty sure if the function calls for a parameter, it needs a parameter...
I'm pretty sure that is what this error is talking about, it is expecting 1 thing and cannot convert to another
  1. That was just a typo. That's fixed.
    2.The keypad.h file is included. I just didnt want to include the whole code. I only included the parts relevant to the problem.
  2. I'm following an example from here:
http://playground.arduino.cc/KeypadTutorial/EventSerialKeypad
Observe that when the "keypadEvent" is defined just below the loop() function. Also, observe that "keypadEvent" is passed as a parameter to keypad.addEventListener() in the setup() function.
That's exactly what I did too. I defined "screenState_keyHandler" and then pass it as a parameter:
So what exactly am I overlooking?
Can you attach all of your code, I'm trying to find any differences, but, I can't follow all of your snippets.
