After compilation of the same program for ESP8266, ESP32 and Pico W the final compilation summary is different fro ESP8266 from those for ESP32 and Pico W.
In ESP32 and Pico W the following lines appear respectively:
The sketch uses 849097 bytes (64%) program storage. Maximum is 1310720 bytes.
Global variables use 52436 bytes (16%) of the dynamic memory and 275244 bytes for local variables. Maximum is 327680 bytes.
The sketch uses 450744 bytes (21%) program storage. Maximum is 2093056 bytes.
Global variables use 76376 bytes (29%) of the dynamic memory. Remains 185768 bytes for local variables. Maximum is 262144 bytes.
ESP8266:
. Variables and constants in RAM (global, static), used 36680 / 80192 bytes (45%)
â•‘ SEGMENT BYTES DESCRIPTION
â• â•â• DATA 1588 initialized variables
â• â•â• RODATA 4884 constants
╚â•â• BSS 30208 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 62827 / 65536 bytes (95%)
â• â•â• ICACHE 32768 reserved space for flash instruction cache
╚â•â• IRAM 30059 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 332572 / 1048576 bytes (31%)
╚â•â• IROM 332572 code in flash
While I understand the wording for the ESP32 and Pico W I cannot relate the ESP8266 compile summary to the program storage, global variables memory usage and maximum program storage size and maximum dynamic memory size as shown for the ESP32 and Pico W.
