Compiling error on simple Serial.begin() call
I'm having trouble in calling a very typical function on a included file at setup() in a single include (.h) file. Here is the extremely simple code:
serial_com.h file:
#pragma once
void setupSerial(int baud_rate);
serial_com.cpp file:
#include "serial_com.h"
    Serial.begin(baud_rate);
    while (!Serial);
    Serial.print("Serial com connected at: ");
    Serial.println(baud_rate);
serial_setup.ino file:
    setupSerial(9600);
    // Do nothing
This is pretty basic, right? And yet the compiler gives me the following error:
Arduino: 1.8.19 (Linux), Board: "Arduino Uno"
sketch/serial_com.cpp: In function ‘void setupSerial(int)’:
serial_com.cpp:5:5: error: ‘Serial’ was not declared in this scope
exit status 1
Can you help me with what's going on? The function Serial.begin(baud_rate) is clearly an included one, is part of the core Arduino, so, how it can't find it? I need this specific kind of arrangement for my projects and if Arduino can't work this way it will make impossible my projects altogether!
serial_com.cpp is compiled separately from your .ino file, so it doesn't get the benefit of all the automagically included Arduino stuff.
Try adding #include <Arduino.h> to the top of the .cpp file.
I included the Arduino.h on the header file and now compiles, like so:
#pragma once
Nevertheless the compiler returned the first line as a red line, this is the output:
Archiving built core (caching) in: /tmp/arduino_cache_228867/core/core_arduino_avr_uno_1621df717313d057c92202babd71649a.a
Sketch uses 1442 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
So, I'm still doubtful this was the real solution...
Please forget I said anything then. Sheesh.
I was writing this reply before seeing anything else, that's why. But after reading your reply I now know indeed this is the solution.
