For the steering of my railway I have developed a very large logic. So to make it easier to maintain I splitted it up into tabs in IDE 2.0.3.
But when I put the code for the attached keyboard (TM1638QYF) in a seperate tab, I got compiler errors.
I'm wondering why ?
I made an abstract of the complete sketch so it's easier to read here in this topic.
So here is the complete sketch
#include <EEPROM.h>
#include <elapsedMillis.h>
#include <MuxShield.h>
// Needed for RS485
#include "RS485_protocol.h"
// Display TM1638
#include <TM1638.h>
#include <TM1638QYF.h>
//TM1638QYF::TM1638QYF(byte dataPin, byte clockPin, byte strobePin)
TM1638QYF module(24, 25, 26);
byte deviceId = 0; //Variable to store data read from EEPROM.
int displayStatus = 0;
elapsedMillis displayTimer;
char displayText0[9]; // string om teksten op Display te tonen
char displayText1[9]; // string om teksten op Display te tonen
char displayText2[9]; // string om teksten op Display te tonen
char displayText3[9]; // string om teksten op Display te tonen
char displayText4[9]; // string om teksten op Display te tonen
int debugRS485 = 0;
boolean debugTreinLocation = false;
boolean debugStation = false;
boolean debugSpeed = false;
int modus = 3;
byte treinID[24];
boolean debugTrein[24];
byte treinIDLinks = 0;
byte treinIDRechts = 0;
void getKey(TM1638QYF* module, word* button) {
*button = module->getButtons();
void displayNumber(TM1638QYF* module, word* value) {
module->setDisplayToDecNumber(*value, 0, false);
void displayString(TM1638QYF* module, char* msgk, int dot) {
module->setDisplayToString(msgk, 1 << dot);
int checkKey(TM1638QYF* module) {
static int keyStatus;
static word oldButton;
static elapsedMillis timerKey;
int key = 0;
boolean sameKey;
word buttons = module->getButtons();
if (buttons != 0) {
if (oldButton == 0) {
timerKey = 0;
if (buttons == oldButton && timerKey < 1000) {
sameKey = true;
sameKey = false;
if (buttons != 0 && !sameKey) {
for (int i = 0; i < 16; i++) {
if (buttons >> i == 1) {
key = i + 1;
Serial.print(F(" Key :"));
Serial.println(key);
oldButton = buttons;
return key;
EEPROM.get(0, deviceId);
Serial.begin(19200); // Initialize serial communications with the PC
Serial.println(F(""));
Serial.print(F("Begin, Id = "));
Serial.println(deviceId, HEX);
sprintf(displayText0, "Begin %02u", deviceId);
displayKeyboard();
// Display TM1638
// virtual void setupDisplay(boolean active, byte intensity);
module.setupDisplay(true, 7);
leesKeyboard(&module);
displayKeyboard();
delay(1);
void leesKeyboard(TM1638QYF* module) {
static int statusKeyboard;
static int functie;
static int key2;
static int key3;
static boolean debug;
static elapsedMillis timerKeyboard;
if (timerKeyboard > 5000) {
statusKeyboard = 0;
functie = 0;
int key = checkKey(module);
if (key != 0) {
timerKeyboard = 0;
if (key != 0) {
switch (statusKeyboard) {
case 0: // lees key1
functie = key;
displayStatus = 1;
displayTimer = 0;
sprintf(displayText1, "%02u", functie);
statusKeyboard = 1;
case 1: // lees key2
key2 = key;
displayStatus = 1;
displayTimer = 0;
sprintf(displayText1, "%02u-%02u", functie, key2);
statusKeyboard = 2;
case 2: // lees key3
key3 = key;
displayStatus = 1;
displayTimer = 0;
sprintf(displayText1, "%02u-%02u-%02u", functie, key2, key3);
statusKeyboard = 3;
default:
statusKeyboard = 0;
if (statusKeyboard == 3) {
switch (functie) {
case 1: // Set treinID
treinID[key2] = key3;
statusKeyboard = 0;
case 2: // Set debugTrein
if (key3 == 1) {
debugTrein[key2] = true;
debugTrein[key2] = false;
statusKeyboard = 0;
case 3: // Debug Station
if (key3 == 1) {
debugStation = true;
displayStatus = 3;
displayStatus = 0;
statusKeyboard = 0;
case 4: // Set treinID
if (key2 == 1) {
treinIDLinks = key3;
if (key2 == 2) {
treinIDRechts = key3;
statusKeyboard = 0;
case 5: // Set modus
if (key2 == 1) {
if (key3 == 1) {
modus = 1;
if (key3 == 2) {
modus = 2;
statusKeyboard = 0;
default:
statusKeyboard = 0;
void displayKeyboard() {
if (displayTimer > 4000 && (displayStatus == 1 || displayStatus == 2)) {
displayStatus = 0;
switch (displayStatus) {
case 0:
displayString(&module, displayText0, 0);
case 1:
displayString(&module, displayText1, 0);
case 2:
displayString(&module, displayText2, 0);
case 3:
displayString(&module, displayText3, 0);
case 4:
displayString(&module, displayText4, 3);
And now splitted
The main part contains only
#include <EEPROM.h>
// Needed for RS485
// Display TM1638
#include <TM1638.h>
First tab is named a_Keyboard
int key = 0;
boolean sameKey;
if (buttons != 0) {
timerKey = 0;
sameKey = true;
sameKey = false;
key = i + 1;
return key;
2nd tab is named b_variables
int debugRS485 = 0;
int modus = 3;
byte treinID[24];
3rd tab is named c_Setup
displayKeyboard();
// Display TM1638
and the last tab is named d_loop
displayKeyboard();
delay(1);
static int functie;
static int key2;
static int key3;
statusKeyboard = 0;
functie = 0;
if (key != 0) {
timerKeyboard = 0;
if (key != 0) {
functie = key;
displayStatus = 1;
displayTimer = 0;
statusKeyboard = 1;
key2 = key;
displayStatus = 1;
displayTimer = 0;
statusKeyboard = 2;
key3 = key;
displayStatus = 1;
displayTimer = 0;
statusKeyboard = 3;
default:
statusKeyboard = 0;
switch (functie) {
statusKeyboard = 0;
if (key3 == 1) {
statusKeyboard = 0;
if (key3 == 1) {
displayStatus = 3;
displayStatus = 0;
statusKeyboard = 0;
if (key2 == 1) {
if (key2 == 2) {
statusKeyboard = 0;
if (key2 == 1) {
if (key3 == 1) {
modus = 1;
if (key3 == 2) {
modus = 2;
statusKeyboard = 0;
default:
statusKeyboard = 0;
displayStatus = 0;
case 0:
case 1:
case 2:
case 3:
case 4:
When I put the first tab named 'a_keyboard' in the main part, there is no compiling error.
The error when I compile the splitted version is
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:13: error: variable or field 'getKey' declared void
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:13: error: 'TM1638QYF' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:13: note: suggested alternative: 'TM1638QYF_h'
TM1638QYF_h
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:24: error: 'module' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:24: note: suggested alternative: 'modff'
modff
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:36: error: expected primary-expression before '' token
void getKey(TM1638QYF module, word* button) {
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:38: error: 'button' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:2:38: note: suggested alternative: 'ultoa'
ultoa
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:20: error: variable or field 'displayNumber' declared void
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:20: error: 'TM1638QYF' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:20: note: suggested alternative: 'TM1638QYF_h'
TM1638QYF_h
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:31: error: 'module' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:31: note: suggested alternative: 'modff'
modff
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:43: error: expected primary-expression before '' token
void displayNumber(TM1638QYF module, word* value) {
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:5:45: error: 'value' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:20: error: variable or field 'displayString' declared void
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:20: error: 'TM1638QYF' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:20: note: suggested alternative: 'TM1638QYF_h'
TM1638QYF_h
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:31: error: 'module' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:31: note: suggested alternative: 'modff'
modff
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:39: error: expected primary-expression before 'char'
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:8:51: error: expected primary-expression before 'int'
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:14: error: 'TM1638QYF' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:14: note: suggested alternative: 'TM1638QYF_h'
TM1638QYF_h
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:25: error: 'module' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:25: note: suggested alternative: 'modff'
modff
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:8:19: error: variable or field 'leesKeyboard' declared void
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:8:19: error: 'TM1638QYF' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:8:19: note: suggested alternative: 'TM1638QYF_h'
TM1638QYF_h
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:8:30: error: 'module' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:8:30: note: suggested alternative: 'modff'
modff
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino: In function 'int checkKey(TM1638QYF*)':
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:31: error: 'int checkKey(TM1638QYF*)' redeclared as different kind of symbol
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\a_keyboard.ino:12:5: note: previous declaration 'int checkKey'
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino: In function 'void loop()':
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:3:3: error: 'leesKeyboard' was not declared in this scope
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:3:3: note: suggested alternative: 'displayKeyboard'
displayKeyboard
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino: In function 'void leesKeyboard(TM1638QYF*)':
D:\marcb\Documenten\Arduino\Issue TM1638QYF in subtab\d_loop.ino:20:28: error: 'checkKey' cannot be used as a function
exit status 1
Compilation error: vaiable or field 'getKey' declared void
