I have got a sensor attached to a0 and to the - and +
its reading about 55 in the current light - which is dusk
where would i put "analogRead"?
int ledPin = 13; // LED is connected to digital pin 13
int sensorPin = 0; // light sensor is connected to analog pin 0
int sensorValue ; // variable to store the value coming from the sensor
pinMode(ledPin, OUTPUT); // sets the ledPin to be an output
Serial.begin(9600); //initialize the serial port
digitalWrite(ledPin, LOW); // turn the LED on
void loop() // run over and over again
if
analogRead(analogPin); // read the input pin
int(sensorvalue <= 55) // if sensor level goes below 55
digitalWrite(ledPin, HIGH); // turn led on
Apologies for the questions? Its for a uni end of year show and dont have long left!
if analogRead(sensorPin); <= 55 // read sensor
if analogRead(sensorPin); => 54 // read sensor
digitalWrite(ledPin, LOW); // turn led off
But its saying the following errors
Blink:26: error: expected primary-expression before '=' token
Blink:26: error: expected primary-expression before '>' token
Blink:27: error: expected `;' before '}' token
if ( analogRead(analogPin) <= 55) // read sensor
it says 'analogPin' was not declared in this scope and then the following errors
Blink:25: error: expected primary-expression before '>' token
Blink:26: error: expected primary-expression before '}' token
Blink:26: error: expected `;' before '}' token
How do i use else?
im struggling to understand this - i have tried searching all over for an answer so thanks for your patience and time
Im wanting to have the lights on when it gets darker (and im trying to figure out how to make the light "twinkle" as it will have fibre optic cables attached to the led)
It now does what i want in regards to turning on and off - now i need to worry about making the led flash but im working with the blink programme so we will see what i come up with.
Edit - this code seems to work
if ( analogRead(sensorPin) <= 100) // read sensor
digitalWrite(ledPin, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
Now - how do i now programme another 14 leds - i want them in groups of two per petal but i cant seem to get just one working on the code! Any help from anyone -
