system
1
I'm trying to join an array of chars into a variable. I'm reading in ASCII chars from a processing sketch.
Example:
char inData[4]={1,2,3,'.',4,5}; //Read in by serial as ASCII
want to try make variable float x equal to:
float x = 123.45
I would appreciate any direction,
Thanks.
This should do it.
float x = atof(inData);
Well, considering that inData is big enough to handle the whole string. You might want to increase the size of the inData array.
Arrch
3
SurferTim:
In addition to adding the null terminator, those numbers need to be characters:
char inData[4]={'1', '2', '3', '.', '4', '5', '\0'};
