Convert Char Array to Int/Float
Hello!
I am using the Serial Monitor for a user interface. I am using this code to read serial input:
while (Serial.available() > 0)
    static char message[50];
    static unsigned int message_pos = 0;
    char inByte = Serial.read();
    if (inByte != '\n' && (message_pos < 49)) {
      message[message_pos] = inByte;
      message_pos++;
      message[message_pos] = '\0';
      Serial.println(message);
      message_pos = 0;
It works perfectly, but I want to use ints/floats for this purpose instead.
How do I convert a char array to int/float?
Thanks! @anon44338819 :slightly_smiling_face:
Full code (click arrow)
   NeoPixel Hue Rotater
   by Max Parisi
   Credit to Adrianotiger for the NeoPixel code (generated from https://adrianotiger.github.io/Neopixel-Effect-Generator/)
   Rotates a hue around a 50-led NeoPixel strip connected to pin 8. Use button connected to pin 2 for 'on/off,' pot connected pin A0 for brightness, pot connected to A1 for LED brightnes on pin 6/hue (on mode 2). Wiring on https://wokwi.com/projects/338095330209825363.
// INCLUDE LIBRARIES
#include <dht.h>
#include <EEPROM.h> // new, not tested
// RESET CODE
void(* resetFunc) (void) = 0;
// FOR NEOPIXEL RAINBOW
class Strip
  public:
    uint8_t   effect;
    uint8_t   effects;
    uint16_t  effStep;
    unsigned long effStart;
    Adafruit_NeoPixel strip;
    Strip(uint16_t leds, uint8_t pin, uint8_t toteffects, uint16_t striptype) : strip(leds, pin, striptype) {
      effect = -1;
      effects = toteffects;
      Reset();
    void Reset() {
      effStep = 0;
      effect = (effect + 1) % effects;
      effStart = millis();
struct Loop
  uint8_t currentChild;
  uint8_t childs;
  bool timeBased;
  uint16_t cycles;
  uint16_t currentTime;
  Loop(uint8_t totchilds, bool timebased, uint16_t tottime) {
    currentTime = 0;
    currentChild = 0;
    childs = totchilds;
    timeBased = timebased;
    cycles = tottime;
// DEFINE VARIABLES
const int neoLeds = 50;
const int neoPin = 8;
const int neo2Leds = 5;
const int neo2Pin = 7;
const int btnPin = 2;
const int brightnessPin = 0;
const int pot2Pin = 1;
const int ledPin = 5;
const int buzzPin = 3;
const int dhtPin = 4;
const int sLedPin = LED_BUILTIN;
int brightnessState, pot2State, brightness, neoSpeed, pixelNum, chk, prePixelNum, hue, incomingByte, incomingBytes, i;
int mode = 1;
byte rgb[3];
float temp, rh, preTemp, preRh;
unsigned long millisOffset;
boolean btnState; // used to be int; not tested
// OPTIONAL SETTINGS (new, not tested), MAKE SURE LESS THAN 255 AND AT LEAST 0 BEFORE WRITING
byte useTest; // 0 = no, 1 = yes
byte sLedAlwaysOn; // 0 = only on startup, 1 = always
byte modeColor[3]; // {r, g, b}
byte mode3Speed; // 0 = no movement, 2.8 = medium, 5 = fast, etc...
byte mode5Background; // {r, g, b}
byte mode5TempColor; // {r, g, b}
byte mode5RhColor; // {r, g, b}
byte ledMax; // LED maximum value, max 255
byte potRange[2]; // pot value range, {min, max}, DIVIDE BY 4 (max value to EEPROM is 255)
byte tempRange[2]; // temp to NeoPixel range, {min, max}
byte rhRange[2]; // humidity to NeoPixel range, {min, max}
// SET UP COMPONENTS
Strip NeoPixel(neoLeds, neoPin, neoLeds, NEO_GRB + NEO_KHZ800);
struct Loop strip0loop0(1, false, 1);
Strip NeoPixel2(neo2Leds, neo2Pin, neo2Leds, NEO_GRB + NEO_KHZ800);
dht DHT;
// SETUP CODE
  pinMode(btnPin, INPUT_PULLUP);
  pinMode(brightnessPin, INPUT);
  pinMode(pot2Pin, INPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(sLedPin, OUTPUT);
  Serial.println("Power On");
  NeoPixel.strip.begin();
  NeoPixel2.strip.begin();
  digitalWrite(sLedPin, HIGH);
  digitalWrite(sLedPin, LOW);
  led(0);
  strip_off();
  strip2_off();
  //test();
  strip_off();
  strip2_off();
  pixel2_up_to(1, 0, 0, 255);
  menu();
// LOOP CODE
  chk = DHT.read11(dhtPin);
  temp = DHT.temperature;
  rh = DHT.humidity;
  brightnessState = pot_to_value(analogRead(brightnessPin));
  brightness = value_to_brightness(brightnessState);
  pot2State = pot_to_value(analogRead(pot2Pin));
  btnState = !digitalRead(btnPin);
  if (btnState) {
    while (btnState) {
      btnState = digitalRead(btnPin);
    mode++;
    while (mode > 5) {
      mode -= 5;
    strip2_off();
    pixel2_up_to(mode, 0, 0, 255);
    if (mode == 3) {
      hue = 0;
    if (mode == 5) {
      preTemp = temp + 1;
      preRh = rh + 1;
    buzz(500);
  switch (mode) {
    case 1:
      all(255, 255, 255);
      led(value_to_led(pot2State));
    case 2:
      led(0);
      hue_to_rgb(value_to_hue(pot2State), rgb);
      all(rgb[0], rgb[1], rgb[2]);
    case 3:
      if (hue > 359) {
        hue -= 360;
      hue_to_rgb(hue, rgb);
      hue += 2.8;
    case 4:
      strips_loop();
    case 5:
      if (!(temp == preTemp) || !(rh == preRh)) {
        all(5, 5, 0);
        pixel(temp_to_pixel(temp), 255, 0, 0);
        pixel(rh_to_pixel(rh), 0, 0, 255);
        preTemp = temp;
        preRh = rh;
    default:
      error("The variable 'mode' went over maximum value.");
  NeoPixel.strip.setBrightness(brightness);
  NeoPixel.strip.show();
  if (brightness <= 0) {
    NeoPixel2.strip.setBrightness(1);
    NeoPixel2.strip.setBrightness(brightness);
  NeoPixel2.strip.show();
  // SERIAL READ (new)
      message_pos++;
      message_pos = 0;
    if (Serial.available() > 0) {
    incomingBytes = Serial.available();
    incomingByte = Serial.read() - 48;
    if (incomingBytes != 1 && incomingByte >= 0 && incomingByte < 10) {
      Serial.print("I got: ");
      Serial.print(incomingByte, DEC);
      Serial.print(" Bytes: ");
      Serial.println(incomingBytes - 2);
  /*if (Serial.available() > 0) {
    incomingByte = Serial.read();
    switch (incomingByte) {
      case 1:
        menu1();
      case 2:
        menu2();
        while (Serial.available() <= 0) {}
        delay(50);
          case 1:
            test();
            menu();
          case 2:
            Serial.println("Hit any key to exit");
              Serial.print("Button Value: ");
              Serial.print(btnState);
              Serial.print(", Brightness Pot Value: ");
              Serial.print(brightnessState);
              Serial.print(", Extra Pot Value: ");
              Serial.print(pot2State);
              Serial.println("\tHit any key to exit");
            menu();
          case 3:
              Serial.print("Current millis(): ");
              Serial.print(millis());
            menu();
          case 4:
            menu();
          default:
            Serial.println("Invalid Request");
            menu1();
      case 3:
        menu3();
        delay(50);
          case 1:
            mode = 1;
          case 2:
            mode = 2;
          case 3:
            mode = 3;
          case 4:
            mode = 4;
          case 5:
            mode = 5;
          case 6:
          default:
            menu1();
      case 4:
        Serial.println("Resetting...");
        resetFunc();
        error("Reset Failed");
      default:
        menu();
// DEFINE FUCTIONS
void strips_loop() {
  if (strip0_loop0() & 0x01)
uint8_t strip0_loop0() {
  uint8_t ret = 0x00;
  switch (strip0loop0.currentChild) {
    case 0:
      ret = strip0_loop0_eff0(); break;
  if (ret & 0x02) {
    ret &= 0xfd;
    if (strip0loop0.currentChild + 1 >= strip0loop0.childs) {
      strip0loop0.currentChild = 0;
      if (++strip0loop0.currentTime >= strip0loop0.cycles) {
        strip0loop0.currentTime = 0;
        ret |= 0x02;
    else {
      strip0loop0.currentChild++;
  return ret;
uint8_t strip0_loop0_eff0() {
  if (millis() - NeoPixel.effStart < neoLeds * (NeoPixel.effStep)) return 0x00;
  float factor1, factor2;
  uint16_t ind;
  for (uint16_t j = 0; j < 52; j++) {
    ind = NeoPixel.effStep + j * 1;
    switch ((int)((ind % 52) / 17.333333333333332)) {
      case 0: factor1 = 1.0 - ((float)(ind % 52 - 0 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 0) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 255 * factor1 + 0 * factor2, 0 * factor1 + 255 * factor2, 0 * factor1 + 0 * factor2);
      case 1: factor1 = 1.0 - ((float)(ind % 52 - 1 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 17.333333333333332) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 0 * factor1 + 0 * factor2, 255 * factor1 + 0 * factor2, 0 * factor1 + 255 * factor2);
      case 2: factor1 = 1.0 - ((float)(ind % 52 - 2 * 17.333333333333332) / 17.333333333333332);
        factor2 = (float)((int)(ind - 34.666666666666664) % 52) / 17.333333333333332;
        NeoPixel.strip.setPixelColor(j, 0 * factor1 + 255 * factor2, 0 * factor1 + 0 * factor2, 255 * factor1 + 0 * factor2);
  if (NeoPixel.effStep >= 52) {
    NeoPixel.Reset();
    return 0x03;
  else NeoPixel.effStep++;
  return 0x01;
int value_to_brightness(int value) {
  if (value >= 1000) {
    return 255;
  } else if (value <= 24) {
    return 0;
    int brightness = map(value, 0, 1024, 0, 100);
    if (brightness < 0) {
      error("In 'value_to_brightness()', 'brightness' is less than 0.");
    if (brightness > 255) {
      error("In 'value_to_brightness()', 'brightness' is greater than 255.");
    return brightness;
int pot_to_value(int pot) {
  int value = map(pot, 200, 800, 0, 1024);
  if (value < 0) {
    value = 0;
  if (value > 1024) {
    value = 1024;
  return value;
int value_to_led(int value) {
  return map(value, 0, 1024, 0, 100);
int value_to_hue(int value) {
  return map(value, 0, 1024, 0, 360);
int hue_to_rgb(float H, byte rgb[]) {
  float C = 1;
  float X = 1 - abs(fmod(H / 60.0, 2) - 1);
  float m = 0;
  float r, g, b;
  if (H >= 0 && H < 60) {
    r = C, g = X, b = 0;
  } else if (H >= 60 && H < 120) {
    r = X, g = C, b = 0;
  } else if (H >= 120 && H < 180) {
    r = 0, g = C, b = X;
  } else if (H >= 180 && H < 240) {
    r = 0, g = X, b = C;
  } else if (H >= 240 && H < 300) {
    r = X, g = 0, b = C;
    r = C, g = 0, b = X;
  r = r * 255;
  g = g * 255;
  b = b * 255;
  if (r < 0) {
    error("In 'value_to_rgb()', 'r' is less than 0.");
  if (r > 255) {
    error("In 'value_to_rgb()', 'r' is greater than 255.");
  if (g < 0) {
  if (g > 255) {
  if (b < 0) {
  if (b > 255) {
  rgb[0] = r;
  rgb[1] = g;
  rgb[2] = b;
int temp_to_pixel(int temp) {
  int pixel = map(temp, 15, 40, 0, (neoLeds - 1));
  if (pixel < 0) {
    pixel = 0;
  if (pixel > (neoLeds - 1)) {
    pixel = neoLeds - 1;
  return pixel;
int rh_to_pixel(int rh) {
  int pixel = map(rh, 30, 90, 0, (neoLeds - 1));
  if (pixel < 0) {
    pixel = 0;
  return pixel;
int pixel(int pixel, int r, int g, int b) {
  if (pixel < 0) {
    error("On function 'pixel()' first parameter (the pixel #) was above 0.");
    error("On function 'pixel()' first parameter (the pixel #) was above LEDs on the NeoPixel Strip (minus 1 because of zero indexing).");
  NeoPixel.strip.setPixelColor(pixel, NeoPixel.strip.Color(r, g, b));
int pixel2(int pixel, int r, int g, int b) {
  if (pixel < 0) {
    error("On function 'pixel2()' first parameter (the pixel #) was above 0.");
  if (pixel > (neo2Leds - 1)) {
    error("On function 'pixel2()' first parameter (the pixel #) was above LEDs on the NeoPixel Strip #2 (minus 1 because of zero indexing).");
  NeoPixel2.strip.setPixelColor(pixel, NeoPixel2.strip.Color(r, g, b));
int pixel_up_to(int pixels, int r, int g, int b) {
  for (i = 0; i < pixels; i++) {
    NeoPixel.strip.setPixelColor(i, NeoPixel.strip.Color(r, g, b));
int pixel2_up_to(int pixels, int r, int g, int b) {
    NeoPixel2.strip.setPixelColor(i, NeoPixel2.strip.Color(r, g, b));
int buzz(int duration) {
  if (duration < 0) {
    error("On function 'buzz()', 'duration' is less than 0..");
  tone(buzzPin, 100, duration);
int error(String info) {
  NeoPixel.strip.setBrightness(255);
  NeoPixel2.strip.setBrightness(255);
  led(0);
  Serial.print("ERROR: ");
  Serial.println(info);
  while (!(digitalRead(btnPin))) {
    buzz(1000);
    all(255, 0, 0);
    all2(255, 0, 0);
    strip_off();
    strip2_off();
  Serial.println("Error Ignored");
void strip_off() {
  all(0, 0, 0);
int all(int r, int g, int b) {
  for (i = 0; i < neoLeds; i++) {
void strip2_off() {
  all2(0, 0, 0);
int all2(int r, int g, int b) {
  for (i = 0; i < neo2Leds; i++) {
int led(int dutyCycle) {
  analogWrite(ledPin, map(dutyCycle, 0, 100, 0, 255));
// MENUS (new, not tested
void menu() {
  Serial.println("\n\n~~~ MENU ~~~");
  Serial.println("1) Settings >");
  Serial.println("2) Test >");
  Serial.println("3) Change Mode >");
  Serial.println("\n4) RESET");
void menu1() {
  Serial.println("\n\n\t~~~ SETTINGS MENU ~~~");
void menu2() {
  Serial.println("\n\n\t~~~ TEST MENU ~~~");
  Serial.println("\t1) Lights");
  Serial.println("\t2) Pot/Button values");
  Serial.println("\t3) Current millis()");
  Serial.println("\n\t4) BACK");
void menu3() {
  Serial.println("\n\n\t~~~ CHANGE MODE ~~~");
  Serial.println("\t1) Mode 1");
  Serial.println("\t2) Mode 2");
  Serial.println("\t3) Mode 3");
  Serial.println("\t4) Mode 4");
  Serial.println("\t5) Mode 5");
  Serial.println("\n\t6) BACK");
void test() {
  Serial.println("~~~ Light Test ~~~");
  buzz(500);
  Serial.println("  Red");
    pixel(i, 255, 0, 0);
    delay(500 / neoLeds);
  delay(250);
  buzz(500);
  Serial.println("  Green");
    pixel(i, 0, 255, 0);
  delay(250);
  buzz(500);
  Serial.println("  Blue");
    pixel(i, 0, 0, 255);
  delay(250);
  buzz(500);
  Serial.println("  Yellow");
    pixel(i, 255, 255, 0);
  delay(250);
  buzz(500);
  Serial.println("  White w/ LED");
  for (i = 0; (i < neoLeds); i++) {
    pixel(i, 255, 255, 255);
    led(map(i, 0, neoLeds, 0, 100));
  led(100);
  strip_off();
  strip2_off();
  led(0);
  buzz(500);
  Serial.println("Done with test");
char charArray1[] = "123";
char charArray2[] = "10.579";
  int i = atoi(charArray1);
  float f = atof(charArray2);
  Serial.begin (115200);
  Serial.println(i);
  Serial.println(f,3);
The atoi() function works perfectly. atof() works sometimes, but with more than 2 decimal places, the float value rounds to 2 decimal places.
Thanks! If I could, I would give this 1/2 of a solution :wink:.
Have you looked at toFloat() - Arduino Reference
How are you displaying the result? Serial.print defaults to 2 decimal places. You need to specify the required decimals.
  Serial.println(f,5);   // 5 d.p.
Oh. That definitely helped!
Now how do I use this as a variable, not in Serial.print()?
tinkerer9
i and f are variables...
No, setting the decimal places.
You don't. The value will be available with whatever the float variable can hold. It's only when you try and print it that it gets rounded.
You can use the round() function if you want.
OK!
Secret (tap arrow)
I didn't test the code before, thinking I was smart, but I'm not :laughing:.
tinkerer9
Assume:
float f = 7.12345678;
The value shown above is just for viewing on the Monitor.
1. When we declare a float number, the compiler saves 32-bit bnary32 (IEEE-754) formatted data into 4 consecutive memory locations as per Fig-1. The integer part, fractional part, and the position of decimal point -- all are there.
Fgure-1:
2. Structure of binary32/IEEE-754 Standard
Figure-2:
Huh? Me not know that :stuck_out_tongue_winking_eye:.
