Hoping to get some advice on setting-up ConfigurableFirmata on an Arduino Nano with an AT328PB.
Added a condition to lump the AT328PB in with nano group during board.h configuration:
// Arduino Duemilanove, Diecimila, Uno, Nano, etc.
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328PB__)
Have ConfigurableFirmata version 3.1.0 loaded in arduino-ide_2.2.1_Linux_64bit.
Set-up serial baud rate in ConfigurableFirmata.ino
//Firmata.begin(115200);
Firmata.begin(57600)
Module enable defines in ConfigurableFirmata.ino:
#include <DigitalInputFirmata.h>
DigitalInputFirmata digitalInput;
#include <DigitalOutputFirmata.h>
DigitalOutputFirmata digitalOutput;
#include <SerialFirmata.h>
SerialFirmata serial;
Arduino serial monitor set to 57600 baud captures the following sequence, whenever the Nano board is reset:
"(Gibber)...ConfigurableFirmata qBooting device. Stand by... qUnknown pin mode q...(repeats last message ad infinitum)."
The repeated 'Unknown pin mode' message is a worry...perhaps best clue?
I copied the Firmata.js example blink.js file, and also set the baud rate for 57600 baud:
const options = {
baud: 57600 // Set your desired baud rate
const board = new Board(port.path, options);
Tail of output from running the blink.js file in 'output debug messages' mode of node, on a USB cable connected Linux box:
user@hostname:~$DEBUG=* node blink.js
serialport/binding-abstract read +6ms
serialport/bindings/unixRead Starting read +1ms
serialport/bindings/unixRead read error [Error: EAGAIN: resource temporarily unavailable, read] {
errno: -11,
code: 'EAGAIN',
syscall: 'read'
} +1ms
serialport/bindings/unixRead waiting for readable because of code: EAGAIN +0ms
serialport/bindings/poller Polling for "readable" +2ms
Many reads initially occur, before the USB serial device /dev/ttyUSB0 becomes unavailable, and communication suspends.
When I run the client blink.js code in node without debug messaging, the output is as follows:
user@hostname:~$node blink.js
manufacturer: '1a86',
serialNumber: undefined,
pnpId: 'usb-1a86_USB2.0-Ser_-if00-port0',
locationId: undefined,
vendorId: '1a86',
productId: '7523',
path: '/dev/ttyUSB0'
board constructed
The board object is created successfully in blink.js...
console.log("board constructed");
...yet the board.on("ready"...) function never executes.
board.on("ready", () => {
console.log("ready");
// Never fires.
The whole ConfigurableFirmata and Firmata.js project folder can be inspected at the following: https://file.io/OuPTk63i3foI
If anyone can follow along, and please tell me why I get the repeated 'Unknown pin mode' message after resetting the Arduino, whilst connected by Arduino serial monitor?
GBEM👽
