Conflict between Touch Screen and RTC
Hello dear forumers,
I'm creating a new post about a component conflict. Indeed For one of my projects i'm using :
  • Arduino UNO R3
  • MCUFriend TFT touch screen 2,4" in kit with arduino : Aliexpress Kit
  • Tiny RTC I2C modules
My RTC is wired on SCL/SDA/+5V/GND
Touch screen shield use A4 as LCD_RST Pin wich is sadly an SDA pin
I have had some trouble to find a correct library and during the research i found that my LCD use a ST7783 Driver wich i can't confirm now.
My problem is that when i use RTC i loose my screen. A simple code i made to test it is :
#include <Adafruit_GFX.h>
#include <UTFTGLUE.h>
#include <SPI.h>
#include <MCUFRIEND_kbv.h>
#include <RTClib.h>
#include <Wire.h>
#include <avr/pgmspace.h>
MCUFRIEND_kbv tft;
RTC_DS1307 rtc;
#include <TouchScreen.h>
#define YP A1
#define YM 7
#define XM A2
#define XP 6
UTFTGLUE myGLCD(0x7783, A2, A1, A3, A4, A0);
#define TOUCH_ORIENTATION  LANDSCAPE
TouchScreen myTouch(XP, YP, XM, YM, 300);
TSPoint tp;
//Hour, minutes, seconds RTC
int h, m, s;
  //Init serial for diagnostics
  //Initialising LCD
  myGLCD.InitLCD(TOUCH_ORIENTATION);
  myGLCD.clrScr();
  myGLCD.fillScr(0,0,0);
  myGLCD.setColor(150,0,25);
  //Init wire and RTC lib .
  Wire.begin();
  rtc.begin();
  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  DateTime now = rtc.now();
  //Serial test on RTC
  m = int(now.minute());
  h = int(now.hour());
  s = int(now.second());
  Serial.print(h);
  Serial.print("\n");
  Serial.print(m);
  Serial.print("\n");
      Serial.print("loop is on \n");
      DateTime now=rtc.now();
      m=int(now.minute());
      h=int(now.hour());
      s=int(now.second());
      myGLCD.printNumI(h,140,120,2,'0');
      myGLCD.print(":",150,120);
      myGLCD.printNumI(m,160,120,2,'0');
      myGLCD.printNumI(s,148,150);
The LCD is Bright white because i guess he is doing some kind of reset again and again.
I have already try to change A4 buy 10 (pin 10 is use for SD Card which i don't use here, or by A3 or any other pins. REsults is the same. Changes were done in :
I have on other unsold problem which involve this time only the Touch screen (maybe it's linked with the previous one).
If i use the touch screen function i cannot modify display anymore until i do a myGLCD.Init() again. For exemple look at this code with 2 menus :
#include <SPI.h>
#include <RTClib.h>
#include <Wire.h>
MCUFRIEND_kbv tft;
RTC_DS1307 rtc;
#define YP A1
#define YM 7
#define XM A2
#define XP 6
TSPoint tp;
int h, m, s;
void RGB()
 myGLCD.fillScr(255,0,0);
 myGLCD.fillScr(0,255,0);
 myGLCD.fillScr(0,0,255);
void PageMenu1()
  //Ligne 1
  myGLCD.setColor(255,255,255);
  myGLCD.drawRect(200,50,240,10);
  myGLCD.drawRect(260,50,300,10);
  //Ligne 2
  myGLCD.drawRect(200,100,240,60);
  myGLCD.drawRect(260,100,300,60);
  //Ligne 3
  myGLCD.drawRect(200,150,240,110);
  myGLCD.drawRect(260,150,300,110);
  //Ligne 4
  myGLCD.drawRect(200,200,240,160);
  myGLCD.drawRect(260,200,300,160);
  //Buton Home
   myGLCD.setColor(150, 0, 175);
   myGLCD.fillRect(90, 200, 220, 240);
   myGLCD.setColor(255, 255, 255);
   myGLCD.setBackColor(150, 0, 175);
   myGLCD.print("HOME", 148, 215);
   myGLCD.setBackColor(0, 0, 0);
void PageMenu2()
  int minutes, secondes;
  int TokenExit=1;
  minutes=0;
  secondes=0;
  //Button Menu1()
   myGLCD.setColor(0, 250, 0);
   myGLCD.print("PARAMETRES", 125, 215);
  do{
    myGLCD.setColor(0,0,0);
    myGLCD.fillRect(140,130,145,110);
    myGLCD.printNumI(minutes,140,120,2,"0");
    myGLCD.fillRect(155,130,175,110);
    myGLCD.setColor(255,255,255 );
    myGLCD.printNumI(secondes,160,120,2,"0");
    Serial.print(secondes);
    secondes=secondes+1;
    tp= myTouch.getPoint();
    if (tp.x <= 680 && tp.x >= 400 && tp.y <= 900 && tp.y >= 820 && tp.z > 20)
    TokenExit = 0;
  }while (TokenExit==1);
  Serial.print("we are out");
  //Initialising LCD
  pinMode(A0, OUTPUT);
  digitalWrite(A0, HIGH);
  myGLCD.clrScr();
 /*Wire.begin();
  rtc.begin();
  Serial.print(h);
  Serial.print("\n");
  Serial.print(m);
  Serial.print("\n");*/
     RGB();
     PageMenu1();
     PageMenu2();
If i use lines :
    TokenExit = 0;
The LCD do not refresh any more (as if i do a ClearScreen or anything else) unitl i do a myGLCD.Init().
Can someone plz help me with my hardware problems :frowning:
I have done some research and just to let you know i'm not using any pull up resistors. MAybe it's a bad point i'm not really good in Hardware and I2C
Refresh problem is fixed but RTC problem is not fixed.... I just can't use RTC with my tft screen This is so boring. Am i doing some mistakes? I2C is not supposed to be an adressed communication? I thought signal to RTC won't cause problems to LCD since they have 2 different adresses.
It IS.
With the RTC and TFT connected to the Arduino, have you run the I2Cscanner sketch, to make SURE that your hardware is correct?
Does either the RTC or the TFT have pullup resistors on the I2C lines?
