Connect analog sensor to Arduino MKR WIFI 1010
Good morning,
I want to test connecting an analog sensor to Arduino WIFI MKR1010.
I connect the circuit displayed below. The problem is that the sketch takes a long time to download and in the end it does not download. I restarted Arduino but still, the sketch does not download. I also tried different PC and encountered the same problem. Is there anything to keep in mind when using MKR arduino inputs/outputs pins when downloading the program.
You made something wrong when uploading the picture, the left side is only grey where the actual connection might be visible.
Download? We usually say "uploading" when transferring a compiled sketch to the board.
What error message do you get? Which exact version of the IDE are you using? What transfer method did you use (USB)?
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to [url=https://forum.arduino.cc/index.php?topic=710766.0]Learn How To Use The Forum[/url].
Other general help and troubleshooting advice can be found here.
