Connect Arduino to computer using serial and usb to serail cable?
Hello ,
I want my Arduino to "talk" with my computer
for this I have a USB-Serial cable
in the Arduino code I ahve setting
#include <SPI.h>
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial SendToCom(8, 9);
  SendToCom.begin(9600);
delay (3000);
SendToCom.println("Done!");
Serial.println("Done");
Serial.println(millis());
SendToCom(millis());
delay(5000);
Serial.println("Again");
SendToCom("Again");
delay(2000);
in the serial usb cable I have connected the Rx\TX\GND 2\3\5 pins to 8\9\gnd on the arduino
but when I open putty on teh computer I see gibrish and spaces in the right times
once every 5 secnod and 2 seconds
did I miss something in the hardware?
if I undesrsatnd correct
the arduino is ttl 5V and the cable\computer is not?
can it be ?
this will explain the gibrish?
(deleted)
9600
but I have found the problem
I need to add max3232 between the computer usbserail to the arduino
after adding it - it's working
Thanks anywahy!
david1234:
It sounds like you have the wrong cable.
If you have a USB-TTL cable there is no need for a MAX3232
...R
Sounds like he is using a cable that plugs into a DB9 port hence the need for a MAX232.
Most PCs don't come with a genuine COM port these days.
ieee488:
The Original Post says "for this I have a USB-Serial cable"
...R
Robin2:
...R
I know.
What he has isn't what we think he has.
ieee488:
I know.
AFAIK you can get some USB cables with RS232 serial at the other end and some with TTL serial at the other end. I have assumed the OP has the first type.
...R
maybe my the wording of the question was wrong...
the usb cable is rs232 with D9 in the end
I thought it's ttl(5V) because it's connected to the USB
after understdng it's not I have connected it throw a max2323 and now it's OK
the important thing is that I learned :slight_smile:
Thank you all
Your post makes no sense without a photo.
A DB9 to USB cable looks like this:
I am at a loss how you were able to connect such a cable between your PC and the Arduino Uno.
