Connect arduino to router via usb (no shield)?!
Can I do that? Thanks for fast response!
Thanks for fast response // OODDSS
1234567890123456789012345678901234567890
Numbers? No! Don't use variables!!!!!!
If your router has a Female Type-A USB port you can connect your Arduino UNO to you router with a USB cable. It won't DO anything but you can connect them. Perhaps the router will provide power to the Arduino.
Yes, you can. I use Mikrotik routers, and here is the thread on the Mikrotik site. I can login to the router using a special login user and connect to the Arduino serial I/O like telnet.
http://forum.mikrotik.com/viewtopic.php?f=3&t=57091
I use this router.
If your router has a USB host port then you can connect a USB cable between that and the Arduino.
