Connect ESP32 - DEVKIT V1 to Azure Web Socket
Hi, first post. Let me know if this is not the correct category to ask for.
I have been doing a small personal Project with a Finger Print Sensor and some Web socket functionality.
Everything was working as expected until I deploy the web socket server to Azure.
It seems my DOIT ESP32 DEVKIT V1 board cannot connect to the Web socket Server.
I'm using the Web Sockets library.
#include <WiFi.h>
#include <WebSocketsClient.h>
#include <HardwareSerial.h>
#include <HTTPClient.h>
String deviceName = "ESP-FG-TNT";
char *ssid = "mySsid";
char *pass = "dummyPass";
String domain = "flowcontrol9a.azurewebsites.net";
int port = 80;
int wifiStatus = WL_IDLE_STATUS;
void connectWifi() {
  WiFi.begin(ssid, pass);
  while (wifiStatus != WL_CONNECTED) {
    wifiStatus = WiFi.waitForConnectResult();
  WiFi.setAutoReconnect(true);
  WiFi.persistent(true);
  Serial.println("[WIFI] WiFi connected!");
  Serial.print("[WIFI] IP address: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
  String sPayload;
	switch(type) {
		case WStype_DISCONNECTED:
			Serial.printf("[WSc] Disconnected!\n");
		case WStype_CONNECTED:
			Serial.printf("[WSc] Connected to url: %s\n", payload);
			// send message to server when Connected
			// webSocket.sendTXT("CONNECTED");
		case WStype_TEXT:
                        //Code here
		case WStype_BIN:
		case WStype_ERROR:
		case WStype_FRAGMENT_TEXT_START:
		case WStype_FRAGMENT_BIN_START:
		case WStype_FRAGMENT:
		case WStype_FRAGMENT_FIN:
void connectSocket() {
  webSocket.beginSSL(domain, port, "/webSocket/" + deviceName);
  webSocket.onEvent(webSocketEvent);
  webSocket.setReconnectInterval(3000);
  WiFi.mode(WIFI_STA);
  Serial.println("[STARTUP] Starting!...");
  connectWifi();
  connectSocket();
  wifiStatus = WiFi.status();
  if(wifiStatus != WL_CONNECTED) connectWifi();
  webSocket.loop();
I got the following on the serial monitor.
[WSc] Disconnected!
What could be occurring since I tried to connect from postman and it worked! Kinda annoying because it works on localhost.
I appreciate it if you can give advice on the correct way to connect to a web socket.
The default port for SSL web traffic is 443. Port 80 is used for non-SSL traffic. Maybe you should try without the "SSL" in the method name.
Yeah, you're right.
