hello
i try to connect esp32 module to my server via websocket
in server code i defined port 3000 to listen by server
i try different way but no success.
can any body help to me
server address: https://ehome.iran.liara.run
my code:
#include <Arduino.h>
#include <WebSocketsClient.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <ESP32Ping.h>
WiFiMulti objWifiMulti;
WebSocketsClient objWebSocketClient;
Serial.println("\n\nBooting; please wait...");
delay(2000);
pinMode(2, OUTPUT);
objWifiMulti.addAP("***", "***");
Serial.print("\n\nBoot complete; connecting to wifi network.");
while (objWifiMulti.run() != WL_CONNECTED)
Serial.print(".");
digitalWrite(2, !digitalRead(2));
Serial.println("\nconnecting to WIFI network successful; assign ip is: " + WiFi.localIP().toString());
digitalWrite(2, HIGH);
//objWebSocketClient.begin("ws://192.168.25.24",3000);
//objWebSocketClient.beginSSL("ehome.iran.liara.run",443,"","","wss" );
objWebSocketClient.begin("ehome.iran.liara.run",80,"","ws");
// objWebSocketClient.beginSocketIO("ehome.iran.liara.run", 3000, "", "wss");
Ping.ping("8.8.8.8");
Serial.print("ping IP 8.8.8.8 in ");
Serial.print(Ping.averageTime());
Serial.println(" ms.");
objWebSocketClient.loop();
objWebSocketClient.sendTXT("test");
my server code
const express = require("express");
const app = express();
const http = require("http");
const server = http.createServer(app);
const { Server } = require("socket.io");
const io = new Server(server);
app.use(express.static(__dirname + "/public"));
app.get("/", (req, res) => {
//res.send({ username: "require", password: "require" });
res.sendFile(__dirname + "/public/assets/index.html");
io.on("connection", (socket) => {
console.log("\nconnection to new Client Stablished by ID: " + socket.id);
socket.on("req_status", (part) => {
console.log("Request status of " + part);
socket.emit("send_status", part, "on");
socket.on("disconnect", () => {
console.log("\nconnection lost from client with ID: " + socket.id);
server.listen(3000, () => {
console.log("Server successfuly running on port 3000.\n\nwaiting for clients...");
Your code should prints a multiple diagnostic messages. Do you see it in the console?
Please insert sketch output to the forum (as text with code tags).
connecting to WIFI network successful; assign ip is: 192.168.25.14
ping IP 8.8.8.8 in 140.52 ms.
ping IP 8.8.8.8 in 137.69 ms.
ping IP 8.8.8.8 in 113.63 ms.
ping IP 8.8.8.8 in 153.82 ms.
ping IP 8.8.8.8 in 120.29 ms.
ping IP 8.8.8.8 in 152.69 ms.
ping IP 8.8.8.8 in 121.92 ms.
ping IP 8.8.8.8 in 76.91 ms.
ping IP 8.8.8.8 in 114.25 ms.
This is another point to check.
Are you sure your hosting service is able to run JavaScript from server side?
I've assumed yes, because the page seems working well, but maybe it was served from a web service like Apache or something like this and not from your script.
hello again
i update my server code and it work fine(i test it with Socket.IO Test Client chrome extension and connection successfully established) my site address
but i still cant connect to server via my esp32 device and get the flowing error in serial monitor
[311164][E][WiFiClient.cpp:313] setSocketOption(): fail on -1, errno: 9, "Bad file number"
and this is my esp32 code
#include <WiFi.h>
delay(2000);
pinMode(2, OUTPUT);
Serial.print(".");
// objWebSocketClient.begin("ws://192.168.25.24",3000);
objWebSocketClient.beginSSL("ehome.iran.liara.run",443,"/","","WSS" );
//objWebSocketClient.begin("ehome.iran.liara.run",443,"","wss");
//objWebSocketClient.beginSocketIOSSL("ehome.iran.liara.run", 443, "/","wss");
hello
finally a completely change the server side(node.js) code with web-socket and successfully connect to it via my esp32.
my esp 32 module now can connect to server but immediately disconnect and this loop happened again
this is the error of my serial monitor that shown
ping IP 8.8.8.8 in 80.41 ms.
[2715728][E][WiFiClient.cpp:313] setSocketOption(): fail on -1, errno: 9, "Bad file number"
ping IP 8.8.8.8 in 88.71 ms.
ping IP 8.8.8.8 in 113.31 ms.
[2728606][E][WiFiClient.cpp:313] setSocketOption(): fail on -1, errno: 9, "Bad file number"
ping IP 8.8.8.8 in 104.36 ms.
ping IP 8.8.8.8 in 108.73 ms.
[2741525][E][WiFiClient.cpp:313] setSocketOption(): fail on -1, errno: 9, "Bad file number"
*** i solve this error according to bellow tutorial; but system still immediately connect and disconnect tutorial Link
and this is my Arduino(esp32) code
#include <WiFi.h>
delay(2000);
pinMode(2, OUTPUT);
Serial.print(".");
objWebSocketClient.beginSSL("ehome.iran.liara.run",443,"/","","wss");
//objWebSocketClient.onEvent(webSocketEvent);
//objWebSocketClient.sendTXT("Hello FROM ESP32!");
//objWebSocketClient.begin("ehome.iran.liara.run", 443, "/", "wss");
and also i get this warning on compiling time
Compiling .pio\build\esp32dev\libd94\ESP32Ping\ping.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
.pio/libdeps/esp32dev/WebSockets/src/WebSocketsServer.cpp: In member function 'WSclient_t* WebSocketsServerCore::handleNewClient(WiFiClient*)':
.pio/libdeps/esp32dev/WebSockets/src/WebSocketsServer.cpp:634:12: warning: function may return address of local variable [-Wreturn-local-addr]
return client;
.pio/libdeps/esp32dev/WebSockets/src/WebSocketsServer.cpp:626:20: note: declared here
WSclient_t dummy = WSclient_t();
Archiving .pio\build\esp32dev\lib273\libWebSockets.a
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Your two topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
