Connect OV7670 Module to Arduino Nano Every
I bought an Arduino Nano Every board and an OV7670 Camera Module to try to connect the camera to the board and stream the live footage to a screen. Since the screen is still being shipped i decided to try to stream the camera's footage directly to my pc. The problem is i never used an arduino before and have no idea how to make it happen. I already connected the needed pins from the cam to the board:
Camera Pin: Arduino Pin
VCC: 3.3V
GND: GND
SCL (Serial Clock): A5
SDA (Serial Data): A4
XCLK (External Clock): D2
PCLK (Pixel Clock): D3
D0-D7 (Data Lines): D4 - D11
VS: D12
HS: D13
For now Chatgpt provided me with the following Arduino Code:
#include <ArduCAM.h>
#include <Wire.h>
// Define ArduCAM pins
#define CS_PIN      10  // Chip Select pin
#define RESET_PIN   9   // Reset pin
#define SDA_PIN     A4  // Serial Data pin
#define SCL_PIN     A5  // Serial Clock pin
// ArduCAM object
ArduCAM myCAM(OV7670, CS_PIN);
  Serial.println(F("ArduCAM Start!"));
  Wire.begin(); // Initialize the I2C bus
  // Initialize ArduCAM module
  myCAM.set_format(JPEG);
  myCAM.InitCAM();
  // Start capture
  myCAM.start_capture();
  // Wait for capture to finish
  while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK)) {
    delay(10);
  // Read image data length
  int imgSize = myCAM.read_fifo_length();
  // Send image data over serial
  for (int i = 0; i < imgSize; i++) {
    Serial.write(myCAM.read_fifo());
  // Delay before capturing next image
Please Help
Also, i connected LEDs to the circuit to see if any data is being communicated. (It is)
Why not ask Chatgpt again?
Doesn't work. The scripts it gives me don't return any image. I've tried to get it to write me good code for 2 days now.
This tutorial appears to cover what you are trying to do in some detail
https://circuitjournal.com/arduino-OV7670-to-pc
