Connecting 0.91 inch 128x32 OLED screen to ESP01S and displaying text
Hi there,
I'm new to using the ESP01S and I'm trying to connect a 0.91 inch 128x32 OLED SSD1306 screen to it. I know how to connect the screen to an Arduino Nano and how to display text using the "u8g2" library, here's the code I use:
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);   // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
void setup(void) {
  u8g2.begin();
void loop(void) {
  u8g2.clearBuffer();					// clear the internal memory
  u8g2.setFont(u8g2_font_ncenB08_tr);	// choose a suitable font
  u8g2.drawStr(0,10,"Hello World!");	// write something to the internal memory
  u8g2.sendBuffer();					// transfer internal memory to the display
But I'm not sure if that library is compatible with the ESP01S or if there is a better library to use. Any suggestions, diagrams or examples of working code would be appreciated.
Library guide and reference page: Home · olikraus/u8g2 Wiki · GitHub
Yes I already tried to read the docs, but as I sad I'm new to all this so I couldn't figure out how to do it
The best approach with new hardware is to start with a library example, and see if it compiles, runs and works as expected on your setup.
I know how to use that OLED screen with my Arduino Nano, and there is an code example I used
Hi @ruku,
Take a look at this EXAMPLE
HTH?
Excellent! Try it with the ESP01S and report back to us.
I tried it without success, that's why I'm asking for help
I will give it a try, thank you!
But you forgot to tell us what you did and what went wrong.
For hints on successful posting, please read and follow the instructions in the "How to get the best out of this forum" post.
Nothing happened, there is nothing that went wrong. I don't know how to do it, that's all.
I've tried
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ 1, /* data=*/ 0, /* reset=*/ U8X8_PIN_NONE);   // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
Connected screen like this - VCC to 5V (from Arduino Nano), GND to GND (also Nano), IO0 to SLC (SCK in my case) and IO2 to SDA
clock is SCL and data is SDA, so I don't know why it's not working
Nothing happened
Really?
Have you connected the computer and display to the ESP01? Powered everything up?
Can you enter any program, and have that program successfully compile and load on the ESP?
If so, did the ESP01 print anything at all on the serial monitor, and otherwise do what you expect?
Did you run the I2C address scanner program to see if the ESP detects the proper display address?
If the answer to all those questions is yes, then try the display program and report what actually happened. It was not "nothing".
Found solution, I was using
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=SCL*/ 0, /* data=SDA*/ 1);
This WAS WRONG, I though "1" was for GPIO2, turns out its "2"
So the working code is
#include <SPI.h>
#endif
#include <Wire.h>
#endif
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, 0, 2);
void setup(void) {
  u8g2.begin();
void loop(void) {
  u8g2.clearBuffer();
  u8g2.sendBuffer();
And if you want to use U8x8 it's like this
U8X8_SSD1306_128X32_UNIVISION_SW_I2C u8x8(0, 2);
