kwhhSt
November 14, 2022, 2:05pm
1
Hello,
I try to use the following configuration;
ESP8266 Serial WIFI Module ESP-01 (blue Version)
USB-to-ESP8266 01 Serial Wireless Wifi Module für ESP-01 for programming
an OLED 0.96 display
When I program it to write or draw something on the display then nothing will be happen.
The power has taken from the programmer module (=USB-to-ESP8266 01)
The SCL and SDA I get from the ESP8266 Serial WIFI Module ESP-01
What could be the problem?
Thanks a lot in advance.
Kurt
hammy
November 16, 2022, 9:54am
3
Need to see a proper schematic and your code !
kwhhSt
November 16, 2022, 10:28am
4
Hello ham. Y,
thank you for your answer.
I made a schematic using fritzing
How can i insert this to the topic?
The code I will add this afternoon.
hammy
November 16, 2022, 9:10pm
5
A Fritzing schematic is no good .
Have a quick read of guides for drawing schematics , draw one ( pencil ) , photograph it and upload into your post
horace
November 17, 2022, 6:58am
6
I find the open source TinyCAD useful for creating schematics
kwhhSt
November 17, 2022, 3:09pm
7
Hello to all you answered
sorry for my late replay!
Thanks a lot for your answers.
Here some about my work:
I made the a code for WiFi connection and output on an OLED (JMD0.96C ) see code below
This works very good as long as I use a NODEMCU
When I connect the OLED to an ESP01 (blue version) nothing happens at all.
When I connect the pin CH_PD to 3.3V then I can see the ESP01 on my wireless network but nothing happends on the OLED
For uploading the programm I use an USB-Adapter modified for upload.
This is the wiring:
a 3.3 V source to pin VCC and CH_PD on ESP01
a 3.3 v source to VCC on OLED
the ground to ground on ESP01 and OLED
the SCL to GPIO0 on ESP01 and OLED
the SDA to GPIO2 on ESP01 and OLED
Thanks.
This is a simple code which works on a NODEMCU
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ESP8266WiFi.h>
const char* WIFI_SSID = "ABC";
const char* WIFI_PASSWORD = "0987654321";
String HostName = "WiFi Tester";
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
delay(5000);
Serial.println("**************");
Serial.println("* Start hier *");
// Setup WIFI
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
WiFi.setHostname(HostName.c_str());
delay(100);
Serial.println("WiFi connected.");
for (byte i = 0; i < 10; i++) {
delay(2000);
// Setup SSD1306
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
kwhhSt
November 19, 2022, 2:59pm
8
Hi to all experts!
Does anybody have an idea what's wrong with my project?
Kurt
ZX80
November 19, 2022, 3:07pm
9
kwhhSt
November 19, 2022, 4:18pm
10
Hi ZX80!
thanks a lot for your hint.
A line
Wire.begin(2,0);
was missing in my code.
Now it works perfect.
Kurt
system
Closed
May 18, 2023, 4:18pm
11
