Connecting 6 Sensirion SFM3013 Sensors to Arduino Mega
Hello! I am trying to connect two SFM-3013-300-CL's to an Arduino via a TCA9548A multiplexer to collect flow and temperature data. I am using the 'exampleusage.ino' file from this github ( arduino-i2c-sfm-sf06/examples/exampleUsage at master · Sensirion/arduino-i2c-sfm-sf06 · GitHub) and have set the I2C multiplexer as specified. However I keep receiving the following error: Error trying to execute readMeasurementData(): Not enough data received.
Here is how I connected them to the Arduino Mega->
This is my code:
#include <SensirionI2cSfmSf06.h>
#include <Arduino.h>
#include <Wire.h>
#define TCAADDR 0x70
SensirionI2cSfmSf06 sensor;
SensirionI2cSfmSf06 sensor2;
static char errorMessage[64];
static int16_t error;
//String myCmd;
void print_byte_array(uint8_t* array, uint16_t len) {
    uint16_t i = 0;
    Serial.print("0x");
    for (; i < len; i++) {
        Serial.print(array[i], HEX);
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
    while (!Serial) {
        delay(100);
    Wire.begin();
    tcaselect(0);
    sensor.begin(Wire, SFM3013_I2C_ADDR_2F);
    tcaselect(0);
    sensor.stopContinuousMeasurement();
    delay(100);
    //uint32_t productIdentifier = 0;
    //uint8_t serialNumber[8] = {0};
    //error = sensor.readProductIdentifier(productIdentifier, serialNumber, 8);
    if (error != NO_ERROR) {
        Serial.print("Error trying to execute readProductIdentifier(): ");
        errorToString(error, errorMessage, sizeof errorMessage);
        Serial.println(errorMessage);
        return;
    tcaselect(0);
    error = sensor.startO2ContinuousMeasurement();
        Serial.print(
            "Error trying to execute startO2ContinuousMeasurement(): ");
        return;
    tcaselect(1);
    sensor2.begin(Wire, SFM3013_I2C_ADDR_2F);
    tcaselect(1);
    sensor2.stopContinuousMeasurement();
    delay(100);
    tcaselect(1);
    error = sensor2.startO2ContinuousMeasurement();
        Serial.print(
        return;
    float aFlow = 0.0;
    float aTemperature = 0.0;
    uint16_t aStatusWord = 0u;
    tcaselect(0);
    error = sensor.readMeasurementData(aFlow, aTemperature, aStatusWord);
        Serial.print("Error trying to execute readMeasurementData(): ");
        return;
    float aFlow2 = 0.0;
    float aTemperature2 = 0.0;
    uint16_t aStatusWord2 = 0u;
    tcaselect(2);
    error = sensor2.readMeasurementData(aFlow2, aTemperature2, aStatusWord2);
        return;
    Serial.print(aTemperature);
    Serial.print(",");
    Serial.print(aTemperature2);
    Serial.print(",");
    Serial.println(aFlow);
    Serial.print(",");
    Serial.print(aFlow2);
My main problem here is that this code and the exact same set up works fine with an Arduino UNO but when connecting it to the Mega it shows me this error:
I am also running this multiplexer code to check whether the Mega recognizes that the multiplexer ports are being used and the output shows that it recognizes them with address 2F (which is what I am using in my code above)
 * TCA9548 I2CScanner.ino -- I2C bus scanner for Arduino
 * Based on https://playground.arduino.cc/Main/I2cScanner/
#include "Wire.h"
  if (i > 7) return;
  Wire.write(1 << i);
// standard Arduino setup()
    while (!Serial);
    Wire.begin();
    Serial.println("\nTCAScanner ready!");
    for (uint8_t t=0; t<8; t++) {
      tcaselect(t);
      Serial.print("TCA Port #"); Serial.println(t);
      for (uint8_t addr = 0; addr<=127; addr++) {
        if (addr == TCAADDR) continue;
        Wire.beginTransmission(addr);
        if (!Wire.endTransmission()) {
          Serial.print("Found I2C 0x");  Serial.println(addr,HEX);
    Serial.println("\ndone");
Any help will be much appreciated! :slight_smile:
The resistors You named "pullup resistors" are not properly wired. The sit there as serial resistors.
remove those inline resistors you have on SD0 and SD1.
