I need to connect an AC (220v) power cable directly to a PCB. Of course I will use optocouplers to separate the high voltage. I am thinking to use one of the following connectors:
A:
B:
Which one of them is best to use? are there any other connectors/methods that can used ?
Thank you.
Look what connectors sit on motor driver boards for direct wire insert. Otherwise you have to configure the power cable with a cable shoe or the like before screwing that assembly to your connector.
With so massive connectors as you show I fear that your Arduino circuit will travel around with every move of the power cable. Did you take strain relief and bend protection into account? You don't want to power a kW load from that mains connection, will you?
After all I think that you should leave that connection and enclosing to a professional.
Hi @szakaria
Why? Are you sensing or controlling?
If sensing, are you looking for voltage or current?
If controlling, what are the characteristics of the load?
As @DrDiettrich suggests, this is a dangerous area from both a safety and litigation perspective! Nobody here should be giving advice that would result in risk of death or injury!
As a matter of principle, you should get a professionally designed module, professionally fitted at the device you are sensing/controlling and just have low voltage back to your processor.
5Amp is not that much.
(plastic) "PCB screw terminals" (Google/images) are the default choice for this.
5.08mm pin spacing should be able to take the right wire size.
Leo..
