Connecting arduino nano 33 iot to wifi
Hi, I have a problem dealing with Arduino Nano 33 IoT. I tried to connect the Arduino Nano 33 IoT to my wifi but then, it some sort like unstable. I already tried scan my networks and my wifi totally stabled. I'm not sure why, I tried to solve the problem in a month but still I could not find a way. Plus, I already used VUSB of Arduino Nano 33 Iot for supplying voltage of 5V to my sensors. Is it related to firmware update or the VUSB itself. The code that I implemented is shown below:
#include <SPI.h>
#include <WiFiNINA.h>
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxxx";
int status = WL_IDLE_STATUS;
WiFiSSLClient client;
void connectToAP(){
while ( status != WL_CONNECTED){
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
Serial.println("Connected...");
void printWifiStatus(){
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
while (!Serial){
if (WiFi.status() == WL_NO_MODULE){
Serial.println("Wifi module failed!");
while(true);
connectToAP();
printWifiStatus();
00:58:47.261 -> Attempting to connect to SSID: xxxxxx
00:58:51.628 -> Connected...
00:58:51.628 -> Attempting to connect to SSID: xxxxxx
00:59:00.543 -> Connected...
00:59:00.543 -> Attempting to connect to SSID: xxxxxx
00:59:04.485 -> Connected...
I mean, if the controller successfully connected, the serial monitor should show the IP Address.
I know this is simple, but have you made sure the password you are giving is the correct one? I had the same problem and then realized the password I had inputted was one character off.
First post here. Got my pw right, stored my SSID in uppercase rather than lower case.
