Connecting CLRC663 to Arduino
Hello,
I want to connect an CLRC663 module to arduino but i have a problem receiving data from CLRC663, the module recognize the tag, but in arduino i am not receiving anything.
This is the datasheet of the module: http://www.nxp.com/documents/data_sheet/CLRC663.pdf
This is the code what i am using:
#include <Wire.h>
#include <EEPROM.h>
// There are 512 bytes of EEPROM available. The data stored there
//remains when the Arduino is switched off or reset
// Each tag uses 5 bytes (1 byte status, 4 bytes tag number),
//so 512 / 5 = 102 cards may be stored
#define MAX_NO_CARDS 102
// define the LED pins:
#define waitingLED 7
#define successLED 8
#define failureLED 9
int toggleState = 0; // state of the toggling LED
long toggleTime = 0; // delay time of the toggling LED
byte tag[4]; // tag serial numbers are 4 bytes long
Wire.begin(); // join i2c bus
Serial.begin(9600); // set up serial port
Wire.beginTransmission(0x28); // the RFID reader's address is 42
Wire.write(0x00); // Length
Wire.write(0x1F); // reset reader
Wire.endTransmission();
// initialize the LEDs:
pinMode(waitingLED, OUTPUT);
pinMode(successLED, OUTPUT);
pinMode(failureLED, OUTPUT);
// print user instructions serially:
Serial.println("n - add card to database");
Serial.println("c - clear entire database");
Serial.println("d - delete card from database");
Serial.println("p - print database");
// delay to allow reader startup time:
delay(2000);
if (Serial.available() > 0) {
// read the latest byte:
char incomingByte = Serial.read();
switch (incomingByte) {
case 'n': // if user enters 'n' then store tag number
seekNewTag();
case 'c':
eraseEEPROM(); // if user enters 'c' then erase database
Serial.println("Database deleted");
case 'd': // if user enters 'd' then delete the last tag
seekAndDeleteTag();
case'p': // if user enters 'p' then print the database
printTags();
else {
//if there's no serial data coming in,
// the default action is to seek new tags:
seekNewTag();
// delay before next command to the reader:
delay(200);
// erase the entire EEPROM memory storage:
void eraseEEPROM(){
for(int i = 0; i < 512; i++){
EEPROM.write(i, 0);
// writes tag number in a location:
void writeTag(int startingAddress, byte byte0, byte byte1, byte byte2, byte byte3){
EEPROM.write( startingAddress5, byte(1));
EEPROM.write(startingAddress
5+1, byte0);
EEPROM.write(startingAddress5+2, byte1);
5+3, byte2);
EEPROM.write(startingAddress*5+4, byte3);
// delete tag from a specified location
void deleteTag(int startingAddress){
EEPROM.write( startingAddress5, byte(0));
5+1, byte(0));
EEPROM.write(startingAddress5+2, byte(0));
5+3, byte(0));
EEPROM.write(startingAddress5+4, byte(0));
// find the first empty entry in the database:
int findEmptyTag(){
for (int startingAddress = 0; startingAddress< MAX_NO_CARDS; startingAddress++){
byte value = EEPROM.read(startingAddress
5);
if (value == byte(0)) {
return(startingAddress);
return(200);
// print the entire database
void printTags(){
for (int thisTag = 0; thisTag< MAX_NO_CARDS; thisTag++){
printOneTag(thisTag);
void printOneTag(int address) {
Serial.print(address);
Serial.print(":");
for (int offset = 1; offset < 5; offset++) {
int thisByte = int(EEPROM.read(address5+offset));
// if the byte is less than 16, i.e. only one hex character
// add a leading 0:
if (thisByte < 0x10) {
Serial.print("0");
// print the value:
Serial.print(thisByte,HEX);
// add a final linefeed and carriage return:
//lookup tag in the database:
int lookupTag(byte byte0, byte byte1, byte byte2, byte byte3){
for (int thisCard = 0; thisCard< MAX_NO_CARDS; thisCard++){
byte value = EEPROM.read(thisCard
5);
if (value != byte(0)){ //it is a valid tag
//see if all four bytes are the same as the ones we're looking for
if(byte0 == EEPROM.read(thisCard5+1) && byte1 == EEPROM.read(thisCard5+2)
&& byte2 == EEPROM.read(thisCard5+3) && byte3 == EEPROM.read(thisCard5+4)) {
return(thisCard);
// if you don't find the tag, return 200;
return(200);
int getTag(){
byte count = 0;
byte valid = 0;
byte byteFromReader = 0;
Wire.write(0x01); // Length
Wire.write(0x82); // Seek for tags
Wire.write(0x83); // Checksum
delay(100);
Wire.requestFrom(0x28, 8); // get data (8 bytes) from reader
count = 0; // keeps track of which byte it is in the response from the reader
valid = 0; // used to indicate that there is a tag there
while(Wire.available()) { // while data is coming from the reader
byteFromReader = Wire.read();
// no RFID found: reader sends character 2:
if ((count == 0) && (byteFromReader == 2)) {
return(0);
if ((count == 0) && (byteFromReader== 6)) {
//if reader sends 6, the tag serial number is coming:
valid = 1;
count++;
if ((valid == 1) && (count > 3) && (count < 8)) {
// strip out the header bytes :
tag[count-4] = byteFromReader;
// all four bytes received: tag serial number complete:
if ((valid == 1) && (count == 8)) {
return(1);
void seekNewTag() {
Serial.println("Waiting for card");
while(getTag() == 0){
// wait for tag
if (millis() - toggleTime > 1000) {
toggle(waitingLED);
toggleTime = millis();
// unless you get a byte of serial data,
if (Serial. available()) {
// break out of the while loop
// and out of the seekNewTag() method:
return;
blink(successLED, 100, 1);
// look it up in the database:
int tagToCheck = lookupTag(tag[0], tag[1], tag[2], tag[3]);
if (tagToCheck != 200){
Serial.println("That tag is already stored");
printOneTag(tagToCheck);
else {
int emptyTagLocation = findEmptyTag();
if (emptyTagLocation != 200){
writeTag(emptyTagLocation, tag[0], tag[1], tag[2], tag[3]);
Serial.println("That tag is new");
printOneTag(emptyTagLocation);
else {
Serial.println("Maximum number of cards stored");
blink(failureLED, 50, 10);
void seekAndDeleteTag() {
Serial.println("Deleting the next card");
// do nothing; wait for tag
// and out of the method:
return;
int tagToDelete = lookupTag(tag[0], tag[1], tag[2], tag[3]);
if (tagToDelete == 200){
Serial.print("That tag is not stored");
else {
deleteTag(tagToDelete);
void toggle(int thisLED) {
toggleState = !toggleState;
digitalWrite(thisLED, toggleState);
void blink(int thisLED, int interval, int count) {
for (int i = 0; i < count; i++) {
digitalWrite(thisLED, HIGH);
delay(interval/2);
digitalWrite(thisLED, LOW);
delay(interval/2);
How DID you connect it? Hopefully you did a better job of that than you did of reading the stickies at the top of the forum, the ones that say read this BEFORE posting code incorrectly.
Any progress on this, OP?
