Connecting esp32 with ps4 controller
When the PS4 Controller cannot connect to/find the ESP32, it just blinks and eventually turns off. But if it connects, it blinks white, then glows white and then glows PS4 blue. And I already successfully connected the Controller to the ESP32 and controlled it with it. But then the next day, without making any changes in the code, the Controller won't connect. It blinks white, glows white but instead of turning blue and fully connect, it just turns off. I then later tried it with a different controller, and now, again without any changes, it connects. About a week later, I tried to connect the controller that worked the last time, and again, it doesn't connect. I'm completely clueless what could possibly cause this issue, I've tried changing the MAC adress in the code and on the controller, but nothing helps.
Just a guess, but are the batteries in the controller fully charged?
Not knowing anything about your code, does the blinking white and glowing white signify anything?
Just to be clear - you're saying that you're using the standard (official) PS4-to-ESP32 interconnect?
See this video - at about 6min 25sec
thankyou sir you saved me
