Connecting FTDI232 adapter with datastreamer on excel
hi,need your help guys!!!
i'm using a ftdi USB to serial adapter with a esp32 ship ,and i want to import the DHT22 data in an excel file using datastream,but unfortunatmmy i can't even connect the device and i get this error in excel:
did you confirm you have comms with your ESP32 thru the ftdi? (using app like putty for example)
did you check you selected the right COM port in your datasteamer settings?
yes i m connecting the esp32 ship using a ftdi usb to serial convertor ,and after selecting the com i got that error message
sigh...you failed to confirm my check items....
Assuming you could your steaming data in the serial monitor, did you close said app(s) and
If you cannot see your data in Serial monitor, their your issue lies elsewhere....
i could now connect the esp32 ,but i don't get any result on DATA_IN using datastreamer ;any suggestions????
here is the code:
#include <esp_now.h>
#include <WiFi.h>
#include "ESPAsyncWebServer.h"
#include <Arduino_JSON.h>
// Replace with your network credentials (STATION)
const char* ssid = "xxx";
const char* password = "xxx";
typedef struct struct_message {
  int id;
  float temp;
  float hum;
  unsigned int readingId;
} struct_message;
struct_message incomingReadings;
JSONVar board;
AsyncWebServer server(80);
AsyncEventSource events("/events");
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac_addr, const uint8_t *incomingData, int len) {
  // Copies the sender mac address to a string
  char macStr[18];
  //Serial.print("Packet received from: ");
  //snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  //Serial.println(macStr);
  memcpy(&incomingReadings, incomingData, sizeof(incomingReadings));
  board["id"] = incomingReadings.id;
  board["temperature"] = incomingReadings.temp;
  board["humidity"] = incomingReadings.hum;
  board["readingId"] = String(incomingReadings.readingId);
  String jsonString = JSON.stringify(board);
  events.send(jsonString.c_str(), "new_readings", millis());
 /* Serial.printf("Board ID %u: %u bytes\n", incomingReadings.id, len);
  Serial.printf("t value: %4.2f \n", incomingReadings.temp);
  Serial.printf("h value: %4.2f \n", incomingReadings.hum);
  Serial.printf("readingID value: %d \n", incomingReadings.readingId);
  Serial.println();*/
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <title> DASHBOARD</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <link rel="icon" href="data:,">
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    p {  font-size: 1.2rem;}
    body {  margin: 0;}
    .topnav { overflow: hidden; background-color: #8F8700; color: white; font-size: 1.7rem; }
    .content { padding: 20px; }
    .card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
    .cards { max-width: 700px; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(300px, 1fr)); }
    .reading { font-size: 2.8rem; }
    .packet { color: #bebebe; }
    .card.temperature { color: #fd7e14; }
    .card.humidity { color: #1b78e2; }
  </style>
</head>
<body>
  <div class="topnav">
    <h3> DASHBOARD</h3>
  </div>
  <div class="content">
    <div class="cards">
      <div class="card temperature">
        <h4><i class="fas fa-thermometer-half"></i>  TEMPERATURE</h4><p><span class="reading"><span id="t1"></span> &deg;C</span></p><p class="packet">Reading ID: <span id="rt1"></span></p>
      </div>
      <div class="card humidity">
        <h4><i class="fas fa-tint"></i> - HUMIDITY</h4><p><span class="reading"><span id="h1"></span> &percnt;</span></p><p class="packet">Reading ID: <span id="rh1"></span></p>
      </div>
    </div>
  </div>
<script>
if (!!window.EventSource) {
 var source = new EventSource('/events');
 source.addEventListener('open', function(e) {
  console.log("Events Connected");
 }, false);
 source.addEventListener('error', function(e) {
  if (e.target.readyState != EventSource.OPEN) {
    console.log("Events Disconnected");
 }, false);
 source.addEventListener('message', function(e) {
  console.log("message", e.data);
 }, false);
 source.addEventListener('new_readings', function(e) {
  console.log("new_readings", e.data);
  var obj = JSON.parse(e.data);
  document.getElementById("t"+obj.id).innerHTML = obj.temperature.toFixed(2);
  document.getElementById("h"+obj.id).innerHTML = obj.humidity.toFixed(2);
  document.getElementById("rt"+obj.id).innerHTML = obj.readingId;
  document.getElementById("rh"+obj.id).innerHTML = obj.readingId;
 }, false);
</script>
</body>
</html>)rawliteral";
  // Initialize Serial Monitor
  // Set the device as a Station and Soft Access Point simultaneously
  WiFi.mode(WIFI_AP_STA);
  // Set device as a Wi-Fi Station
  WiFi.begin(ssid, password);
    Serial.println("Setting as a Wi-Fi Station..");
  Serial.print("Station IP Address: ");
  Serial.print("Wi-Fi Channel: ");
  Serial.println(WiFi.channel());
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  esp_now_register_recv_cb(OnDataRecv);
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html);
  events.onConnect([](AsyncEventSourceClient *client){
    if(client->lastId()){
      Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
    // send event with message "hello!", id current millis
    // and set reconnect delay to 1 second
    client->send("hello!", NULL, millis(), 10000);
  server.addHandler(&events);
  server.begin();
  Serial.println("CLEARDATA");
  Serial.println("LABEL,Temperature,Humidity");
  static unsigned long lastEventTime = millis();
  static const unsigned long EVENT_INTERVAL_MS = 5000;
  if ((millis() - lastEventTime) > EVENT_INTERVAL_MS){
    events.send("ping",NULL,millis());
  Serial.print(incomingReadings.temp);
  Serial.print(",");
  Serial.print(incomingReadings.hum);
  Serial.println(",");
  delay(2000);
