Hi, I am trying to connect my Arduino MKR 1010 to eduroam using the WiFiNINA sample code ConnectWithWPA2Enterprise in the library, and I find the input parameters as below:
WiFi.beginEnterprise(ssid, username, password, identity, ca);
Parameters
ssid: the SSID (Service Set Identifier) is the name of the WiFi network you want to connect to.
username: username part of WPA2 Enterprise (RADIUS) credentials
password: password part of WPA2 Enterprise (RADIUS) credentials
identity: WPA2 enterprise identity (optional)
ca: root certificate (string) to validate against (optional)
From the Generic settings for eduroam secure WiFi access on my university, I got the following information:
*Network name (SSID)*
The network name for the secure WiFi network is **eduroam**. This must be all lowercase.
*WiFi authentication and encryption*
The WiFi Network Authentication type is **WPA2 Enterprise**.
The Data Encryption method to use is **AES**.
If your WiFi device does not support WPA2/AES, select **WPA** authentication and **TKIP** encryption.
*User authentication*
The "EAP Authentication Type" or "Outer Authentication Protocol" is **PEAP** or **PEAPv0**.
The "Authentication Method", "Authentication Protocol" or "Inner Authentication Protocol" is **MS-CHAPv2**.
If asked for an "Outer Identity", "Anonymous Identity" or "Roaming Identity", leave it blank.
If asked for a realm, leave it blank.
*Server authentication*
You should choose to **Validate the Server Certificate**.
The certificate should one called **QuoVadis Root CA 2 G3**.
From this information, I can fill in the said ("eduroam"), my username and my password, but I am a little bit confused about the identity and the certificate.
I tried:
WiFi.beginEnterprise(ssid, username, password);
WiFi.beginEnterprise(ssid, username, password, "", "QuoVadis Root CA 2 G3");
WiFi.beginEnterprise(ssid, username, password, "MS-CHAPv2", "QuoVadis Root CA 2 G3");
WiFi.beginEnterprise(ssid, username, password, "WPA", "QuoVadis Root CA 2 G3");
WiFi.beginEnterprise(ssid, username, password, "WPA2 Enterprise", "QuoVadis Root CA 2 G3");
but none of them works.
My firmware version is 1.3.0, which should meet the requirement ( this feature requires NINA firmware version 1.3.0 or later) of this library (and that's also the latest version I can get from the Arduino IDE firmware updater).
Does anyone know what the identity and ca are, and how can I fill the parameters in this sample code in order to connect to eduroam?
