I'm currently working on a project which requires me to connect an Ultrasonic sensor and a magnetometer. So Ive got an Adafruit Motorshield but both ultrasonic and the magnetometer require the pins A4 and A5. How exactly do I connect them. Do all analog pins have the same functionalities. Is there a significant reason for using A4 and A5?
Thank you
lucario_sorcerer:
If they're I2C devices yes, but are they?
If they are both I2C, then there's no problem as long as they both have different I2C addresses, but you'll need to use a breadboard or similar to double up the wiring on those pins.
Also, on an Uno at least, not sure of others, there are duplicate I2C A4/A5 pins next to Aref by the reset button, but I wouldn't know if your shield exposes those or not.
edit: see photo here.
