Hello! I am trying to run a YOLO (you only look once) model on my laptop, and have a python script communicate with my arduino. However, the communication only happens after the script is closed. Please help!\
Python Code:
from ultralytics import YOLO
import serial
import time
arduino = serial.Serial(port='COM5', baudrate=9600, timeout=1)
def send_data(data):
print(f"Sending: {data}")
arduino.write(f"{data}\n".encode())
time.sleep(0.1)
response = arduino.readline().decode().strip()
if response:
print(f"Arduino Responded: {response}")
if __name__ == "__main__":
time.sleep(2)
print("Connected To Arduino")
model = YOLO('best.pt')
# If using a USB camera, change number to 1
results = model(0, show= True)
for results in results:
boxes = results.boxes
classes = results.names
for box in results.boxes:
class_id = int(box.cls[0])
confidence = float(box.conf[0])
detected_class = classes[class_id]
if detected_class == "Garbage" and confidence > 0.65:
send_data("g")
elif detected_class =="Recycling" and confidence > 0.65:
send_data("r")
elif detected_class =="Compost" and confidence >0.65:
send_data("c")
time.sleep(10)
send_data("g")
Arduino Code
#include <AFMotor.h>
// Number of steps per output rotation
// Change this as per your motor's specification
const int stepsPerRevolution = 2048;
// connect motor to port #2 (M3 and M4)
AF_Stepper left_motor(stepsPerRevolution, 1);
AF_Stepper right_motor(stepsPerRevolution, 2);
while (!Serial);
left_motor.setSpeed(10); // 10 rpm
right_motor.setSpeed(10);
if (Serial.available()) {
String data = Serial.readString();
Serial.print("Recieved:");
data.trim();
if (data =="g"){
left_motor.step(512, FORWARD, DOUBLE);
right_motor.step(512, BACKWARD, DOUBLE);
delay(5000);
right_motor.step(512, FORWARD, DOUBLE);
left_motor.step(512, BACKWARD, DOUBLE);
delay(3000);
data.trim();
if (data == "r"){
left_motor.step(1280, FORWARD, DOUBLE);
right_motor.step(256, BACKWARD, DOUBLE);
delay(5000);
right_motor.step(256, FORWARD, DOUBLE);
left_motor.step(1280, BACKWARD, DOUBLE);
delay(3000);
data.trim();
if (data == "c") {
left_motor.step(256, FORWARD, DOUBLE);
right_motor.step(1280, BACKWARD, DOUBLE);
delay(5000);
right_motor.step(1280, FORWARD, DOUBLE);
left_motor.step(256, BACKWARD, DOUBLE);
delay(3000);
