@horace
Thankyou for your link , it worked perfectly.
Now what do you say let's move toward oled ?
what OLED do you have?
have a look at guide-for-oled-display-with-arduino
get it working then worry about adding it to your program
Hi , @horace I have tried the link which you provided and oled is working fine with arduino. Now comes the ethernet part.
Actually I want it to work like the led one which you provided in post#39.
Like when ever check box was clicked led was on and off vice versa.
Similarly as shown below that when ever I click a check box out of four check boxes. For eg a text 'Go Up' is displayed with the arrow in that direction.
if it is a choice "one out of four" you should use a fieldset with 4 radio buttons.
Don't use checkboxes, otherwise the user could check several checkboxes at once.
Try it yourself:
Ethernet W5500 - simple webpage with radio buttons
// Ethernet web page with radio buttons
// original code from https://startingelectronics.org/tutorials/arduino/ethernet-shield-web-server-tutorial/web-server-LED-control/
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
delay(2000);
Serial.println("Ethernet WebServer Example");
// start the Ethernet connection:
// attempt to configure using DHCP if it fails static IP address
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Serial.println(" attempt to set static IP address"); // start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
delay(1000); // FIX: added to give DUE time to find the Ethernet cable
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// print your local IP address:
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
delay(2000);
server.begin(); // start to listen for clients
// possible commands
enum command { UP,
DOWN } command = UP;
const char* commands[] = { "UP", "DOWN" };
static char line[100] = { 0 }; // holds line of text from client
static int lineIndex = 0; // index into line
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
if (c >= ' ') { // if printable character add to line
if (lineIndex < 99) line[lineIndex++] = c; // array overflow?
line[lineIndex] = 0;
//Serial.print(c);
// if none printable character check for \n and lastline was enpty - if so transmit HTTP
if (c == '\n' && lineIndex == 0) {
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
client.println("<!DOCTYPE html>");
client.println("<html>");
client.println("<head>");
client.println("<title>Arduino radio button Control</title>");
client.println("</head>");
client.println("<body>");
client.println("<h1>Controls</h1>");
client.println("<form method=\"get\">");
// send radio buttons checked if required
if (command == UP)
client.println("<input type=\"radio\" id=\"go_up\" name=\"command\" value=\"UP\" checked>");
client.println("<input type=\"radio\" id=\"go_up\" name=\"command\" value=\"UP\">");
client.println("<label for=\"go_up\">UP</label><br>");
// print radio buttons checked or not
if (command == DOWN)
client.println("<input type=\"radio\" id=\"go_down\" name=\"command\" value=\"DOWN\" checked>");
client.println("<input type=\"radio\" id=\"go_down\" name=\"command\" value=\"DOWN\">");
client.println("<label for=\"godown\">DOWM</label><br><br>");
client.println("<input type=\"submit\" value=\"Submit\">");
client.println("</form>");
client.println("</body>");
client.println("</html>");
// if end of line check for GET
Serial.println(line); // print all response
if (strstr(line, "GET /?command") != NULL) {
// set up command to UP or DOWN
if (strstr(line, "command=UP") != NULL) command = UP; // UP is selected
if (strstr(line, "command=DOWN") != NULL) command = DOWN; // UP is selected
Serial.print("******** command = ");
Serial.println(commands[command]);
lineIndex = 0; // zero for next line of text
line[0] = 0;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
//Serial.print("\n******** command = ");
//Serial.println(commands[command]);
} // end if (client)
serial monitor output as UP and DOWN buttons pressed and Submit clicked
My IP address: 192.168.1.177
GET / HTTP/1.1
GET /favicon.ico HTTP/1.1
GET /?command=DOWN HTTP/1.1
******** command = DOWN
GET /?command=UP HTTP/1.1
******** command = UP
the webpage
Edit: worth noting the the original LCD code used a String Class object to hold the received data
OK on a microprocessor like the ESP32 but not recommended for a micro with low SRAM like the UNO - memory becomes fragmented and can cause problems
the radio button code above uses a char array to hold the received data
@horace , Thankyou I am in process of attempting it.
However I have one question is it possible to use long wires connection like 1m between w5500 and arduino uno , I tried to do it but it said ethernet shield not detected.
both SPI and I2C were intended to interconnect devices on PCBs or PCBs close to each other
I have used I2C with 1 meter long low capacitance cable - never attempted it with SPI
move the W5500 close to the UNO and use a longer ethernet cable??
@horace Hi horace I finalized everything regarding the ip to oled connection but , sadly due to small enclosure size of my hardware(received) I had to change the ethernet shield and get a smaller one which is enc28j60.
It arrived yesterday, I wanted to request that maybe the arduino forum could help me for only the basic verification of ip opening process similar to the 'webserver code'. I read about the UIP library and everything but needs some assurance on it's connections+code+library.
you just plugin the nano into the Ethernet shield as shown in your third photo
using the EthernetENC library I run the following code
/* Web Server using a ENC28J60 ethernet shield
https://github.com/JAndrassy/EthernetENC
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <EthernetENC.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
// You can use Ethernet.init(pin) to configure the CS pin
Ethernet.init(10); // Most Arduino shields
//Ethernet.init(2); // MKR ETH shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet
//Ethernet.init(11); // ESP8266 with Adafruit Featherwing Ethernet
while (!Serial) {
/*if (Ethernet.hardwareStatus() == EthernetNoHardware) {
while (true) {
// start the server
server.begin();
Serial.print("server is at ");
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
when run serial monitor displays
server is at 192.168.1.177
new client
GET / HTTP/1.1
Host: 192.168.1.177
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8
Accept-Language: en-GB,en;q=0.5
Accept-Encoding: gzip, deflate
DNT: 1
Sec-GPC: 1
Connection: keep-alive
Upgrade-Insecure-Requests: 1
client disconnected
the webclient displays
@horace Hope you are doing good , I was'nt able to give you update because my ethernet shield got burned and as it is not available in my country , I have to wait for atleast one month to reach it here. So finally I received it checked it with arduino nano, it worked fine then moved for the oled process and as you mentioned in your post # 48 that due to low memory it will cause problems and yes exactly the same thing is happening.
Therefore I wanted to ask you is there a possibility that we can do like Only creating a text box through html where we can type any command like forward , left , right etc and these commands being displayed on oled. without have low memory problem.
the SSD1306Ascii text only OLED library only uses a few bytes of memory
it may help!
Edit: running File>Examples>SSD1306Ascii>wire128x64 on a Nano
Thankyou , I tried the example and it worked fine, however I am confused how to use the SSD1306Ascii library along the relevant code.
I tried few ways but unfortunately either the HTML did'nt worked or ethernet shield was'nt communicating with oled.
try Nano Webserver with OLED
Circuit:
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
by Arturo Guadalupi
byte mac[] = {
#include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
// 0X3C+SA0 - 0x3C or 0x3D
#define I2C_ADDRESS 0x3C
// Define proper RST_PIN if required.
#define RST_PIN -1
SSD1306AsciiWire oled;
Wire.begin();
Wire.setClock(400000L);
#if RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS, RST_PIN);
#else // RST_PIN >= 0
oled.begin(&Adafruit128x64, I2C_ADDRESS);
#endif // RST_PIN >= 0
oled.setFont(System5x7);
#if INCLUDE_SCROLLING == 0
#error INCLUDE_SCROLLING must be non-zero. Edit SSD1306Ascii.h
#endif // INCLUDE_SCROLLING
// Set auto scrolling at end of window.
oled.setScrollMode(SCROLL_MODE_AUTO);
while (!Serial) {
oled.println("Ethernet WebServer");
while (true) {
// start the server
server.begin();
Serial.print("server IP ");
oled.print("Web IP ");
oled.println(Ethernet.localIP());
if (client) {
oled.println("new client");
Serial.write(c);
client.println();
if (c == '\n') {
delay(1);
client.stop();
@horace
Hi Horace, Hope you're doing well.
I got it working through your help and everyone's guide but was not able to update due to exams and studies, just took a moment to thankyou guys.
probably worth clicking the Solution button at the bottom of the reply that answered the question - this helps others with a similar question
