connection does not work with TEMBOO
connection does not work with TEMBOO sketch SendDataToGoogleSpreadsheet and SendAnEmail, but it works sketch Temperaturewebinterface.
Does anyone have any idea to solve this?
Franc
Have you tried other temboo examples? Is your yun connected to internet? Is HTTPClient example working?
HTTP Client not working.
What can I to do?
Franc
Is your yun connected to internet? I mean: have you configured to access internet, like having connected it to your wifi or plugged in an ethernet cable?
where can I configure wifi connecten to yun?
I already made basic configurations. Is there any other settings to access wifi internet.
Franc
I think what you need to do is to connect your Yun on your home network, either by WiFi or Ethernet. Then you should have access to the internet.
If you use the wifi then you should visit: http://arduino.cc/en/Guide/ArduinoYun#toc13
Hope it helps
I already made this configurations: http://arduino.cc/en/Guide/ArduinoYun#toc13.
But temboo ( sketch SendDataToGoogleSpreadsheet) does not work.
Franc
Can you upload WifiStatus example and then (being sure you've selected COM or /dev/tty... port) open the Serial Monitor and paste its output here?
I solved. If I exclude sentence "while(!Serial)" sketch "SendDataToGoogleSpreadsheet" works.
If you can explain why?
Franc
// for debugging, wait until a serial console is connected
delay(4000);
// while(!Serial);
Serial.print("Initializing the bridge...");
Bridge.begin();
Serial.println("Done");
  delay(4000);
  while (!Serial);
while (!Serial); is a common way to force a sketch to continue execution ONLY after user has opened the serial monitor
