Connection MOSFET
Hey
As an endwork, I need to close an electric ball valve after 5 minutes when a flow sensor detects whether water is flowing. The electric ball valve works at 12 volts and Arduino does not have this. That's why I need a MOSFET. Does anyone know how to connect this?
Thanks in advance!
MOSFET:
https://nl.aliexpress.com/item/3V-5V-Low-Control-High-Voltage-12V-24V-36V-E-switch-Mosfet-Module-For-Arduino/32672259362.html?spm=2114.010208.3.1.tStmlH&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10501_10000074_10503_10000032_119_10000025_10000029_430_10000028_10060_10000067_10062_10056_10055_10000062_10054_10059_10099_10000022_10103_10102_10096_10000018_10000019_10000056_10000059_10052_10053_10107_10050_10106_10051_10000053_10000007_10000050_10084_10083_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10000041_10000044_10078_10079_10000038_429_10073_10000035_10121-10051_10503_10501,searchweb201603_1,afswitch_1,single_sort_1_default&btsid=93b7c163-16af-4681-a434-db74f3cae9d0
Flow Sensor:
https://nl.aliexpress.com/item/New-Water-Flow-Sensor-Switch-Meter-Flowmeter-Hall-Flow-Counter-Sensor-Water-Control-Free-Shipping-Water/32333336396.html?spm=2114.30010308.3.358.l5okHU&ws_ab_test=searchweb0_0%2Csearchweb201602_2_10091_10090_10088_10089%2Csearchweb201603_1&btsid=31052f65-9644-4b9c-b37f-61a410b13a4b
Electric ball valve:
https://nl.aliexpress.com/item/HSH-Flo-1-2-DN15-DC12V-Brass-Two-Way-Motorized-Ball-Valve-CR-02-3-Wires/32361181734.html?spm=2114.010208.3.2.U7m5p9&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10068_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10032_10099_10078_10079_10077_10073_10097_10100_10096_10070_10052_10050_10051_424,searchweb201603_9&btsid=8435317d-aa64-475d-901c-19c65232dfd2
How the hell is this a Programming issue?
Is Google down today?
