so on one of your Arduinos you need to use WiFiClient which will require an SSID and password to connect to the WiFi router.
there's no chance of establishing a connection to the other device if it is WiFi and hasn't connected to the WiFi router
again, and again , have you simply tries using the Ethernet or Wifi functions to report you localIP? is it set to what you think it is
here is some older code i used to communicate between WiFi devices (esp32). (i've abandoned this approach for broadcast UDP)
#ifdef ESP32
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
#include "eeprom.h"
#include "node.h"
#include "wifi.h"
int dbgWifi = 1;
// WiFi and JMRI Server Definitions
WiFiClient wifi;
#define EEPROM_CREDENTIALS
#ifndef EEPROM_CREDENTIALS
const char *ssid = "wally";
const char *pass = "Pan0rama";
const char *host = "192.168.0.41";
#else
char host [STR_SIZE] = "";
char ssid [STR_SIZE] = "";
char pass [STR_SIZE] = "";
#endif
int port = 4445;
const char *Nstr [] = { "N_NUL", "N_INIT", "N_UP", "N_DOWN" };
enum { N_NUL, N_INIT, N_UP, N_DOWN };
struct Node {
int state;
char ip [16];
// IPAddress ip;
WiFiClient client;
#define MaxClient 10
Node nodes [MaxClient] = {
{ N_INIT, "192.168.0.41" },
int nNodes = 1;
void
wifiIpAdd (
char *ip )
if (MaxClient <= nNodes) {
printf ("%s: maxClients, %d, reached\n", __func__, nNodes);
return;
Node *p = nodes;
for (int n = 0; n < nNodes; n++, p++)
if (! strcmp (p->ip, ip)) {
printf ("%s: duplicate %s\n", __func__, ip);
return;
nodes [nNodes].state = N_INIT;
strcpy (nodes [nNodes].ip, ip);
nNodes++;
void
wifiIpClr (void)
nNodes = 0;
char *
wifiIpGet (
int idx )
if (nNodes <= idx)
return NULL;
return nodes [idx].ip;
void
wifiIpList (void)
printf ("%s:\n", __func__);
Node *p = nodes;
for (int n = 0; n < nNodes; n++, p++) {
printf (" %s: %2d: %d %-8s ", __func__, n, p->state, Nstr [p->state]);
printf ("%s\n", p->ip);
enum { ST_NUL, ST_INIT, ST_GET_CREDENTIALS, ST_CHK, ST_UP, ST_ERROR };
const char *wifiStStr [] = {
"ST_NUL",
"ST_INIT",
"ST_GET_CREDENTIALS",
"ST_CHK",
"ST_UP",
"ST_ERROR"
int state = ST_NUL;
int stateLst = ST_NUL;
// connect to wifi
void wifiInit (void)
WiFi.mode (WIFI_STA);
#ifdef ESP32
WiFi.hostname (name);
#else
printf ("default hostname: %s\n", WiFi.hostname().c_str());
printf ("new hostname: %s\n", WiFi.hostname().c_str());
#endif
printf ("%s: ssid %s, pass %s\n", __func__, ssid, pass);
WiFi.begin (ssid, pass);
bool
wifiCheck (void)
static unsigned long msecLst = 0;
if ( (msec - msecLst) < 1000)
return false;
msecLst = msec;
printf (" %s:", __func__);
if (WL_CONNECTED != WiFi.status ()) {
printf (" not connected\n");
return false;
IPAddress ip = WiFi.localIP ();
printf (" connected %d:%d:%d:%d\n", ip [0], ip[1], ip [2], ip[3]);
return true;
// connect to jmri
void nodeConnect (void)
do {
printf (" ... Node connecting - %s %d\n", host, port);
} while (! wifi.connect(host, port));
printf (" connected Node %s %d\n", host, port);
// display wifi responses on serial monitor
void wifiReceive (void)
static char cLst = 0;
while (wifi.available()) {
char c = wifi.read ();
if ('\r' == c)
continue;
if ('\n' == cLst && '\n' == c)
continue;
Serial.write (c);
cLst = c;
// common routine for sending strings to wifi and flushing
void
wifiSend (
const char* msg )
if (ST_UP != state)
return;
if (dbgWifi) {
printf ("wifiSend: %s\n", msg);
Node *p = nodes;
// handle re/connect
if (N_INIT == p->state) {
if (p->client.connect (p->ip, port)) {
p->state = N_UP;
Serial.print (" successful connect to ");
else {
p->state = N_DOWN;
Serial.print (" failed connect to ");
Serial.println (p->ip);
// attempt send if connected
if (N_UP == p->state) {
if (! p->client.print (msg)) {
p->state = N_INIT; // make one attempt to re-connect
Serial.print (" failed to send to ");
else {
p->client.flush ();
Serial.print (" send succeeded to ");
void
wifiGetCredentials (void)
#ifdef EEPROM_CREDENTIALS
if (! eepromRead (ID_HOSTNAME, host, sizeof(host))) {
printf ("%s: no hostname\n", __func__);
state = ST_ERROR;
error = ERR_NO_HOST;
if (! eepromRead (ID_SSID, ssid, sizeof(host))) {
printf ("%s: no ssid\n", __func__);
state = ST_ERROR;
error = ERR_NO_SSID;
if (! eepromRead (ID_PASSWORD, pass, sizeof(host))) {
printf ("%s: no password\n", __func__);
state = ST_ERROR;
error = ERR_NO_PASS;
#endif
void
wifiReset (void)
printf ("%s: ssid %s, pass %s, host %s\n", __func__, ssid, pass, host);
state = ST_NUL;
void
wifiMonitor (void)
if (stateLst != state)
printf ("%s: %d %s\n", __func__, state, wifiStStr [state]);
stateLst = state;
switch (state) {
case ST_NUL:
if (ssid [0])
state = ST_INIT;
else {
printf ("%s: no SSID\n", __func__);
state = ST_ERROR;
case ST_INIT:
wifiInit ();
state = ST_CHK;
#if 0
case ST_GET_CREDENTIALS:
wifiGetCredentials ();
if (ST_ERROR != state) {
printf ("%s: credentials acquired\n", __func__);
wifiInit ();
state = ST_CHK;
#endif
case ST_CHK:
if (wifiCheck ())
state = ST_UP;
case ST_UP:
case ST_ERROR:
default:
