Hello,
I cannot connect to the Ethernet Shield 2. I do have the following message
10:48:37.591 -> Ethernet WebServer Example
10:48:38.107 -> Ethernet shield was not found. Sorry, can't run without hardware. ![]()
This is with the tutoriel of the Arduino WebServer, Thanks in advance.
Best Regards, Edern Ollivier.
I use this code :
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino WIZnet Ethernet shield.
Circuit:
- Ethernet shield attached to pins 10, 11, 12, 13
- Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xA8, 0x61, 0x0A, 0xAE, 0xE0, 0xCA
// 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
//IPAddress ip(192, 168, 1, 177);
IPAddress ip(169, 254, 1, 100);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// You can use Ethernet.init(pin) to configure the CS pin
Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH Shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit FeatherWing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit FeatherWing Ethernet
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Ethernet WebServer Example");
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// start the server
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an HTTP request ends with a blank line
bool currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the HTTP request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard HTTP response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("");
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
Idem, it doesn't work with another IP adress.
Web Server
Circuit:
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
by Arturo Guadalupi
#include <SPI.h>
byte mac[] = {
IPAddress ip(10, 10, 2, 14);
while (!Serial) {
while (true) {
// start the server
server.begin();
if (client) {
Serial.write(c);
client.println();
client.println("");
client.println("");
client.println("
client.println("");
if (c == '\n') {
delay(1);
client.stop();
Good, I have solved by DHCP the troubleshoot, please see the code below ![]()
DHCP-based IP printer
This sketch uses the DHCP extensions to the Ethernet library
to get an IP address via DHCP and print the address obtained.
Circuit:
created 12 April 2011
modified 9 Apr 2012
by Tom Igoe
by Arturo Guadalupi
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
// port utilisé (par défaut 80 pour le protocole HTTP)
//Ethernet.init(10); // Most Arduino shields
while (!Serial) {
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
} else if (Ethernet.linkStatus() == LinkOFF) {
// no point in carrying on, so do nothing forevermore:
while (true) {
delay(1);
// print your local IP address:
Serial.print("My IP address: ");
server.begin();
switch (Ethernet.maintain()) {
case 1:
//renewed fail
Serial.println("Error: renewed fail");
case 2:
//renewed success
Serial.println("Renewed success");
//print your local IP address:
case 3:
//rebind fail
Serial.println("Error: rebind fail");
case 4:
//rebind success
Serial.println("Rebind success");
default:
//nothing happened
// crée un objet client basé sur le client connecté au serveur
if (client) { // si le client existe
// message d'accueil dans le Terminal Série
Serial.println ("Client present !");
while (client.connected()) { // tant que le client est connecté
if (client.available()) { // si des octets sont disponibles en lecture
// le test est vrai si il y a au moins 1 octet disponible
char c = client.read(); // lit l'octet suivant reçu du client (pour vider le buffer au fur à mesure !)
} // --- fin client.available
else { // si pas de caractères disponibles = requete client terminée
// message Terminal Serie
Serial.println ("Reception requete terminee");
// envoi d'une entete standard de réponse http
client.println();
// affiche chaines caractères simples
client.print("Hello World"); // page HTML simple
Serial.println ("Reponse envoyee au client");
break; // on sort de la boucle while
// on donne au navigateur le temps de recevoir les données
delay(1);
// fermeture de la connexion avec le client
client.stop();
