Connection of Voltage Detection Sensor and Common Ground (esp32 as microcontroller)
Good day! Since I won't be using a breadboard for my circuit because I will place it in an enclosure, I'm still not sure if my connections are correct.
For now, I already connected the battery by soldering to the switch, then switch to the buck converter (to convert 7.4v to 5v), and it works
I also connected the esp32 to the adxl and it does it job (detecting vibrations) - I did this by just using the USB connector to the laptop.
My uncertainty lies with the voltage sensor and common ground.
• in the diagram, I plan to connect voltage sensor VCC and GND to Buck Out+ and Buck Out-
• for the S, is to the D32 (gpio32) in the esp32, and negative terminal (-) to the buck IN- for detection of battery health
• I also plan to connect the 5v(VIN) and GND of esp32 to Buck Out+ and Buck Out-
• for the gnd of the adxl345, I plan to maintain its vcc connection to 3.3v of esp32 but change its gnd connection to Buck Out- for the common ground.
Is my plan correct? I need to solder these connections since the breadboard I need is not available in the shops rn so I'm trying to not have any errors in the connection😓
Your wiring diagram is extremely hard to read. But if that's a SPDT switch and if the common terminal is the one on the right, you're going to have a very bad day when you short the positive output of that 7.4V battery to ground.
Thank you for this comment. I just checked right now with my multimeter in continuity mode, and indicates a short circuit. I think I reversed my wiring, so the one in the right (com terminal) should be connected to the battery directly right? and the other terminal I connected to the battery should've been connected to Buck In + right?
I have no idea how the terminals on your switch are arranged. No one does. You haven't shown actual parts, given us part numbers, anything.
Let's just hope you connected your resistance meter when the circuit was powered. If so that is good but useless. Any unpowered reading will look like a short because of conduction by the static protection diodes all ICs have.
Hmm? Not sure what you're saying here, if you got a PCB nothing could be easier.
I wasn't planning on using any boards since I 3d printed a case for the esp32 and the sensor😅 I'm just uncertain if I the common ground should be placed on the buck out- and also the connection of the voltage sensor
Dead bug soldering, or wires then...
Since you don't have a PCB where a ground plane could solve this, you'll have to create one yourself. You pick a good spot like the buck converter, and make it the center of a GND star. Ditto for Vcc.
thank you
