Console gives "'lcd' does not name a type" after verifying code
I've been trying to make my code display a message if a condition is met, everything else is working well and I have plugged everything according to order but it tells me that lcd does not name any type, so far I've been told to put "lcd" besides the parenthesis of the "liquid crystal" line and switch the line to the setup loop, but the error still shows up, anyone got any idea what this could entail and how to fix it?
#include <Servo.h>
#include <LiquidCrystal.h>
#define echo 6
#define trig 7
//lcd
#define lcd_E 8
#define lcd_4 10
#define lcd_5 11
#define lcd_6 12
#define lcd_7 13
#define lcd_RS 5
LiquidCrystal lcd(lcd_RS, lcd_E, lcd_4, lcd_5, lcd_6, lcd_7);
Servo servo;
float duration, distance;
  lcd.begin(16, 2);
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
  pinMode(9, OUTPUT);
  servo.attach(9);
  // Print a message to the LCD.
  Sonic();
  if (distance < 10) {
    wave();
    Sonic();
    lcd.print("hello, world!");
    servo.write(150);
    lcd.print("waiting...");
void Sonic() {
  digitalWrite(trig, LOW);
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echo, HIGH);
  distance = (duration * .0343) / 2;
  Serial.print("Distance: ");
  Serial.println(distance);
  delay(100);
void wave() {
  Serial.println("waving");
  servo.write(0);
  delay(100);
  servo.write(90);
  delay(100);
Welcome to the forum
Please post the full error message copied from the IDE using the button provided for the purpose. When you post it please use code tags
The sketch compiles OK for me
Hello, I just realized the reason the code was failing was because I was loading up an older copy by accident, my apologies, I will keep in mind to submit the error for next time, thank you for your help.
pls mark as solution
will do, thank you
