I want to construct a constant current hot wire anemometer. After designing the circuit, i started to build it. As i am studying in mechanical engineering, i have a little knowledge in arduino. The theory of the project told me that when the air flows over the hot wire,it's temperature changes. this change can be expressed by wire resistance. But i am in deep trouble how i get the air velocity from wire resistance by arduino. If anyone would come forward to help me,it will be great help to me. Is there any sample arduino code which i can use for my project? Here is my circuit diagram:
[jremington : handy to have a moon temperature thermometer - how did you do it?]
Most modern cars have a mass air flow sensor using exactly this principle.. ..so it's possible
They use two identical wires in the airflow : one heated, one not ( to compensate for ambient temperature) .
The current through the heated wire is controlled so as to hold it at a fixed temperature above the unheated reference, and the current required depends on the velocity of the airflow.
Buy one from the major car makers.
Or make your own using two light bulb filaments. (glass enclosure removed!)
Look up the resistivity variation with temperature of various metals. I think tungsten is about 6ppm/C
Or use 2 small ntc thermistors - their variation is much bigger - about -4% /C
Yes, Mars has some sort af atmosphere. My fault. Let it be as it is.
When you are in between Earth and Moon you will have to go another 200,000 kms.
In between Earth and moon it is very very cold.
Coming closer to the moon it will get warmer for a sensor directed at the moon (temperatures on the moon: up to more than 100 degrees on the side we can see - and up to minus 145 degrees on the shady side).
Even Pluto is warmer than its environment (still pretty cold). A temperatute sensor that works at low temperatures should be able to detect this.
Please do not tell me that the avarage temperature on the Moon is 0 degrees Kelvin (minus 273 Celsius).
By the way: NON SEQUITUR ....
I like this, I had to learn Latin for years. I hated it, but it helped me a lot to understand some Italian and learn Spanish.
OK. I don't like repeating myself, or being ignored, and I've already asked youtwice to not to change the topic title in your replies, so please accept the forum timeout.
