hey
i am trying to create a continuous motion of a stepmotor nema 17 with AccelStpper library and A4988 driver.
each loop i am reading the speed from the speed control analogInput, writing it to the setSpeed() and sending to the driver with runSpeed(), and continue to the rest of the loop calculation.
the problem is that the motor is moving as long as the arduino isnt doing something else.
for example: when i run the code with a delay(1000) after the run command, it wil move for 1000ms, and than stop for few ms while computing the rest of the code, and run again in the second loop.
is there a way to create a smooth, speed controllable motion while doing other computes?
code below:
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); //sometimes the adress is not 0x3f. Change to 0x27 if it dosn't work.
//Thermistor needed libraries
#include <thermistor.h> //Download it here: https://electronoobs.com/eng_arduino_thermistor.php
thermistor therm1(A0,0); //Connect thermistor on A0, 0 represents TEMP_SENSOR_0 ( configuration.h for more)
//I/O
int PWM_pin = 5; //Pin for PWM signal to the MOSFET driver (the BJT npn with pullup)
int speed_pot = A1;
int but1 = 7;
int EN = 2;
int STEP = 3;
int DIR = 2;
int LED = 13;
//Variables
float set_temperature = 200; //Default temperature setpoint. Leave it 0 and control it with rotary encoder
float temperature_read = 0.0;
float PID_error = 0;
float previous_error = 0;
float elapsedTime, Time, timePrev;
float PID_value = 0;
int button_pressed = 0;
int menu_activated=0;
float last_set_temperature = 0;
int max_PWM = 255;
//Stepper Variables
int max_speed = 3000;
int main_speed = 0;
bool but1_state = true;
bool activate_stepper = true;
int rotating_speed = 0;
float timeBeforeRun;
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper1(1, STEP, DIR); // (Type of driver: with 2 pins, STEP, DIR)
//PID constants
int kp = 90; int ki = 30; int kd = 80;
int PID_p = 0; int PID_i = 0; int PID_d = 0;
float last_kp = 0;
float last_ki = 0;
float last_kd = 0;
int PID_values_fixed =0;
pinMode(EN, OUTPUT);
digitalWrite(EN, HIGH); //Stepper driver is disbled
stepper1.setMaxSpeed(max_speed);
pinMode(but1, INPUT_PULLUP);
pinMode(speed_pot, INPUT);
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
pinMode(PWM_pin,OUTPUT);
TCCR0B = TCCR0B & B11111000 | B00000010; // D6 adn D6 PWM frequency of 7812.50 Hz
Time = millis();
TCCR1A = 0; //Reset entire TCCR1A register
TCCR1B = 0; //Reset entire TCCR1B register
TCCR1A |= B00000010; // /8
TCNT1 = 0; //Reset Timer 1 value to 0
Serial.begin(9600); //initialize serial communication at a baud rate of 9600
lcd.init();
lcd.backlight();
if(!digitalRead(but1) && but1_state){
but1_state = false;
activate_stepper = !activate_stepper;
Serial.println("________________________________________________________________________________change");
Serial.println(activate_stepper);
delay(10);
else if(digitalRead(but1) && !but1_state){
but1_state = true;
if(activate_stepper){
digitalWrite(LED, HIGH);
digitalWrite(EN, LOW); //We activate stepper driver
rotating_speed = map(analogRead(speed_pot),0,1024,main_speed,max_speed);
stepper1.setSpeed(rotating_speed);
timeBeforeRun = millis();
stepper1.runSpeed();
digitalWrite(EN, HIGH); //We deactivate stepper driver
stepper1.setSpeed(0);
// First we read the real value of temperature
temperature_read = therm1.analog2temp(); // read temperature
//Next we calculate the error between the setpoint and the real value
PID_error = set_temperature - temperature_read + 6;
//Calculate the P value
PID_p = 0.01*kp * PID_error;
//Calculate the I value in a range on +-6
PID_i = 0.01*(PID_i + (ki * PID_error));
//For derivative we need real time to calculate speed change rate
timePrev = Time; // the previous time is stored before the actual time read
Time = millis(); // actual time read
elapsedTime = (Time - timePrev) / 1000;
//Now we can calculate the D calue
PID_d = 0.01*kd*((PID_error - previous_error)/elapsedTime);
//Final total PID value is the sum of P + I + D
PID_value = PID_p + PID_i + PID_d;
//We define PWM range between 0 and 255
if(PID_value < 0){
PID_value = 0;
if(PID_value > max_PWM){
PID_value = max_PWM;
//Now we can write the PWM signal to the mosfet on digital pin D5
analogWrite(PWM_pin,PID_value);
previous_error = PID_error; //Remember to store the previous error for next loop.
delay(250); //Refresh rate + delay of LCD print
lcd.clear();
lcd.setCursor(0,0);
lcd.print("T: ");
lcd.print(temperature_read,1);
lcd.print(" S: ");
lcd.print(rotating_speed);
lcd.setCursor(0,1);
lcd.print("PID: ");
lcd.print(PID_value);
}//Void loop end
