Hey,
we have a problem with the controlling of our Continuous Rotation Servo Motor.
The Ultrasonic sensor should measures the distance, and if the distance is above 20cm,
the servo should turn. And if the distance is below 20cm the motor should not start turning.
We don't know how to get further with this problem, cause it seems like we can't even get the Servo to stop at all.
we use Arduino Uno, Ultrasonic sensor (HC-SR04), and Servo (Parallax Continuous rotation)
#include <Servo.h>
Servo servo1;
int position1 = 0;
int trigger = 7;
int echo = 6;
long dauer = 0;
long entfernung = 0;
servo1.attach(10);
Serial.begin (9600);
pinMode(trigger, OUTPUT);
pinMode(echo, INPUT);
digitalWrite(trigger, LOW);
delay(5);
digitalWrite(trigger, HIGH);
delay(10);
dauer = pulseIn(echo, HIGH);
entfernung = (dauer/2) * 0.03432;
if (entfernung >= 300 || entfernung <= 0)
Serial.println("Kein Messwert");
Serial.print(entfernung);
Serial.println(" cm");
if (entfernung >= 20)
if (position1 >= 360) {
position1 = 0;
while (position1 < 360)
servo1.write(position1);
delay(0);
position1++;
You probably shouldn't be using a while loop as it will take a few seconds for position1 to roll over into the negative for the while condition to be false.
Just have it to where it checks the distance and if it's above 20cm, position1 increments and if not then don't increment it.
Also make it unsigned this way you don't need to deal with roll over and just use the modulos % to keep it between 0 and 360, instead of the IF statement that resets position back to zero.
remove the delay too. Or if you need a delay then do it with a millis timer. Look up the example sketch "Blink without delay" to see how to implement this.
That loop will spin at a very high speed. It ought to give a terrible acceleration.
How/when/where should the servo stop?
Ten milliseconds is about a thousand times longer than it actually takes to trigger an ultrasonic ranger.
Where did you find that code?
Hey, so i tried a couple things, and now the "system" works.
But i do think the delay is kinda long ( from when the sensor reads the distance to actually turning on / off the servo).
The code got srambled together from many other codes
#include <Servo.h>
Servo servo1;
int trigger = 7;
int echo = 6;
long dauer = 0;
delay(5);
delay(10);
servo1.attach(8);
servo1.write(180);
delay(10);
if (entfernung < 20)
servo1.detach();
delay(0);
Definitely not how I would have done it but if it works I won't argue the matter.
i got that code from > Funduino
Hi there, as someone that has tried this...it doesn't work. Continuous servos are annoying! You cannot control position, you are better off just using motors.
I'll link my code below:
//Includes libraries necessary for operation
#include <Servo.h> //add Servo Motor library
#include <Ultrasonic.h> //add Ultrasonic sensor library
//Defines Parameters
Ultrasonic ultrasonic(7);
#define MAX_DISTANCE 300 // sets maximum useable sensor measuring distance to 300cm
#define MAX_SPEED 180 // sets speed of DC traction motors to 150/250 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 40 // this sets offset to allow for differences between the two DC traction motors
#define COLL_DIST 1// sets distance at which robot stops and reverses to 30cm
#define TURN_DIST COLL_DIST+20 // sets distance at which robot veers away from object
//Gives each servo names
Servo M1;
Servo M2;
Servo M3;
Servo M4;
Servo Sense;
//Defines movement
const int FORWARD = 180;
const int BACKWARD = 0;
const int RELEASE = 90;
//Defines distances for turning
int leftDistance, rightDistance; //distances on either side
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-------------------------------------------- SETUP LOOP ----------------------------------------------------------------------------
Sense.attach(11);
M1.attach(10); // attaches the servo on pin 10 (SERVO_1 on the Motor Drive Shield to the servo object
M2.attach(9);
M3.attach(6);
M4.attach(5);
ultrasonic = ultrasonic.read(CM);
//---------------------------------------------MAIN LOOP ------------------------------------------------------------------------------
Sense.write(90); // move eyes forward
curDist = digitalRead(7); // read distance
if (curDist < COLL_DIST) {changePath();} // if forward is blocked change direction
moveForward(); // move forward
// defines the movement of the wheels
void changePath() {
moveStop(); // stop forward movement
Sense.write(36); // check distance to the right
rightDistance = readPing(); //set right distance
Sense.write(144); // check distace to the left
delay(700);
leftDistance = readPing(); //set left distance
Sense.write(90); //return to center
delay(100);
compareDistance();
void compareDistance() // find the longest distance
if (leftDistance>rightDistance) //if left is less obstructed
turnLeft();
else if (rightDistance>leftDistance) //if right is less obstructed
turnRight();
else //if they are equally obstructed
turnAround();
int readPing() { // read the ultrasonic sensor distance
delay(70);
unsigned int cm = ultrasonic.read();
return cm;
void moveStop() {M1.write(RELEASE); M2.write(RELEASE); M3.write(RELEASE); M4.write(RELEASE);} // stop the motors.
void moveForward() {
motorSet = "FORWARD";
M1.write(FORWARD); // turn it on going forward
M2.write(FORWARD); // turn it on going forward
M3.write(FORWARD); // turn it on going forward
M4.write(FORWARD); // turn it on going forward
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
M1.write(speedSet);
M2.write(speedSet);
M3.write(speedSet);
M4.write(speedSet);
delay(5);
void moveBackward() {
motorSet = "BACKWARD";
M1.write(BACKWARD); // turn it on going backward
M2.write(BACKWARD); // turn it on going backward
M3.write(BACKWARD); // turn it on going backward
M4.write(BACKWARD); // turn it on going backward
M1.write(speedSet);
M2.write(speedSet);
M3.write(speedSet);
M4.write(speedSet);
delay(5);
void turnRight() {
motorSet = "RIGHT";
M1.write(FORWARD); // turn motor 1 forward
M2.write(FORWARD); // turn motor 2 forward
M3.write(BACKWARD); // turn motor 3 backward
M4.write(BACKWARD); // turn motor 4 backward
M3.write(speedSet+MAX_SPEED_OFFSET);
M4.write(speedSet+MAX_SPEED_OFFSET);
delay(200); // write motors this way for 1500
M1.write(FORWARD); // set both motors back to forward
M2.write(FORWARD);
M3.write(FORWARD);
M4.write(FORWARD);
void turnLeft() {
motorSet = "LEFT";
M1.write(BACKWARD); // turn motor 1 backward
M2.write(BACKWARD); // turn motor 2 backward
M1.write(speedSet+MAX_SPEED_OFFSET);
M2.write(speedSet+MAX_SPEED_OFFSET);
M3.write(FORWARD); // turn motor 3 forward
M4.write(FORWARD); // turn motor 4 forward
delay(2000); // write motors this way for 1500
void turnAround() {
motorSet = "RIGHT";
delay(1700); // write motors this way for 1700
M2.write(FORWARD);
M3.write(FORWARD);
M4.write(FORWARD);
