I'm looking for advice what device is appropriate for both Arduino Due and Uno, to control 9 servo motors from controller with single board to include it into assembly box of my project and avoid extra soldering or manual connection on breadboard
And [USB USC-32 Channel Servo UART Controller Board Unit for DIY ROBOT for Arduino](https://www.amazon.in/Hobbypower Hobbypower-Channel-Arduino-Controller-USC-32/dp/B00HUO926M)
First off all I want use 6 units of this E-flite EFLRDS76TG servos, because it is fast 0.03 sec/60° 4.8V to accelerate maximal part weight about 180g with short range of degree
my breadboard connection is 5V and ground to servos on pins, servos not powered someway separately, controller plugged with 9V adapter
I want avoid powering with 5V output of an Arduino and use a separate power supply for servos, but I'm not sure, how to power it with 12V or 9V when motor uses 4.8-5V ?
I don't know, if it is more than 20-40mA current, standard servo should be between 1 and 2 amps max in operation.
As I found, most hobby servos have a startup current of an ampere or so, and consume several hundred mA when moving
Robin2:
An Uno can control up to 12 servos without needing any external boards.
But the servos must have their own power supply.
...R
Hello
Yes, I don't know if particular motors requires more than say 20-40mA current, anyway I want avoid power servos with 5V output of Arduino, but I'm not sure, how to power it with 12V or 9V when motor uses 4.8-5V ? Reason to use some board, is compactness of connecting the wires from motors, to include it in assembly casing
aive:
Why would you consider powering the servos with 12v or 9v? Just give them the correct voltage. Most servos are happy between 4.8v and 6v - but check the specs for your servos.
Robin2:
...R
I'm not sure how, If controller powered with USB or 9V power adapter and output to servos 5V, but I have to power servos with 5V separately
For example scheme with PCA9685 16 channel Servo controller shows that PCA9685 16 powered with 5V and ground from Arduino with two servos, with many motors powered separately:
My goal is to keep usb and one single power wire from assemble. How properly provide 5V to supply enough current to servos, what power supply I have to use, and how to separate power for controller and servos from one power source
