Im trying to add a 4 digit to the code, it works but somthing strange happen if i go over 999.
The stepper moves as it needs to all the way up to 1600 mm, if i add exemple 1650mm the stepper moves the outher way
Do i need to add somthing to use 4digit to the code to make it work like it does from 0 to 1600?
[[code]
`#include // AccelStepper Library
#include // Keypad Library
#include “U8glib.h” // U8glib for Nokia LCD
// Variables to hold entered number on Keypad
volatile int firstnumber=99; // used to tell how many numbers were entered on keypad
volatile int secondnumber=99;
volatile int thirdnumber=99;
volatile int fourthnumber=99;
// Variables to hold Distance and CurrentPosition
int keyfullnumber=0; // used to store the final calculated distance value
String currentposition = “”; // Used for display on Nokia LCD
// Keypad Setup
const byte ROWS = 4; // Four Rows
const byte COLS = 4; // Four Columns
char keys[ROWS][COLS] = {
{‘1′,’2′,’3′,’A’},
{‘4′,’5′,’6′,’B’},
{‘7′,’8′,’9′,’C’},
{‘*’,’0′,’#’,’D’}
byte rowPins[ROWS] = {22, 24, 26, 28}; // Arduino pins connected to the row pins of the keypad
byte colPins[COLS] = {31, 33, 35, 37}; // Arduino pins connected to the column pins of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // Keypad Library definition
// U8glib Setup for Nokia LCD
#define backlight_pin 11
U8GLIB_PCD8544 u8g(3, 4, 6, 5, 7); // Arduino pins connected to Nokia pins:
// CLK=3, DIN=4, CE=6, DC=5, RST=7
// AccelStepper Setup
AccelStepper stepper(1, A0, A1); // 1 = Easy Driver interface
// Arduino A0 connected to STEP pin of Easy Driver
// Arduino A1 connected to DIR pin of Easy Driver
// parte pin reset carrello
void setup(void) {
// Light up the LCD backlight LEDS
analogWrite(backlight_pin, 50); // Set the Backlight intensity (0=Bright, 255=Dim)
// AccelStepper speed and acceleration setup
stepper.setMaxSpeed(1400); // Not to fast or you will have missed steps
stepper.setAcceleration(400); // Same here
// Draw starting screen on Nokia LCD
u8g.firstPage();
do {
u8g.drawHLine(0, 15, 84);
u8g.drawVLine(50, 16, 38);
u8g.drawHLine(0, 35, 84);
u8g.setFont(u8g_font_profont11);
u8g.drawStr(0, 10, “ENTER DISTANCE”);
u8g.drawStr(62, 29, “MM”);
u8g.drawStr(4, 46, “cur-pos”);
while( u8g.nextPage() );
void loop(){
char keypressed = keypad.getKey(); // Get value of keypad button if pressed
if (keypressed != NO_KEY){ // If keypad button pressed check which key it was
switch (keypressed) {
case ‘1’:
checknumber(1);
case ‘2’:
checknumber(2);
case ‘3’:
checknumber(3);
case ‘4’:
checknumber(4);
case ‘5’:
checknumber(5);
case ‘6’:
checknumber(6);
case ‘7’:
checknumber(7);
case ‘8’:
checknumber(8);
case ‘9’:
checknumber(9);
case ‘0’:
checknumber(0);
case ‘*':
deletenumber();
case ‘#':
calculatedistance();
void checknumber(int x){
if (firstnumber == 99) { // Check if this is the first number entered
firstnumber=x;
String displayvalue = String(firstnumber); // Transform int to a string for display
drawnokiascreen(displayvalue); // Redraw Nokia lcd
if (secondnumber == 99) { // Check if it’s the second number entered
secondnumber=x;
String displayvalue = (String(firstnumber) + String(secondnumber));
if (thirdnumber == 99) { // Check if it’s the 3rd number entered
thirdnumber=x;
String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber));
} else { // It must be the 3rd number entered
fourthnumber=x;
String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber) + String(fourthnumber));
void deletenumber() { // Used to backspace entered numbers
if (fourthnumber !=99) {
String displayvalue = (String(firstnumber) + String(secondnumber) + String(fourthnumber));
fourthnumber=99;
else {
if (thirdnumber !=99) {
thirdnumber=99;
else {
if (secondnumber !=99) {
secondnumber=99;
else {
if (firstnumber !=99) {
String displayvalue = “”;
firstnumber=99;
void calculatedistance() { // Used to create a full number from entered numbers
if (fourthnumber == 99 && thirdnumber == 99 && secondnumber == 99 && firstnumber != 99) {
keyfullnumber=firstnumber;
movestepper(keyfullnumber);
if (secondnumber != 99 && thirdnumber == 99 && fourthnumber == 99) {
keyfullnumber=(firstnumber*10)+secondnumber;
if (thirdnumber != 99 && fourthnumber == 99) {
keyfullnumber=(firstnumber*100)+(secondnumber*10)+thirdnumber;
if (fourthnumber != 99) {
keyfullnumber=(firstnumber*1000)+(secondnumber*100)+(thirdnumber*10)+fourthnumber;
resetnumbers(); // Reset numbers to get ready for new entry
void movestepper(int z) { // Move the stepper
long calculatedmove=(z*1600)/80; // Calculate number of steps needed in mm
stepper.runToNewPosition(calculatedmove);
currentposition = String(z);
u8g.firstPage();
do {
u8g.setPrintPos(57,47);
u8g.print(currentposition);
void resetnumbers() { // Reset numbers for next entry
firstnumber=99;
secondnumber=99;
thirdnumber=99;
fourthnumber=99;
void drawnokiascreen(String y) {
u8g.firstPage();
do {
u8g.setPrintPos(0,29);
u8g.print(y); // Put entered number on Nokia lcd
u8g.print(currentposition); // Display current position of stepper
/code]
