Hi guys!
Im working on a project where i need to read data from an AHU, like fresh air temp, extraction temp and so on.
I got a Arduino UNO wifi rev2 and a TTL to RS485 converter, see attached wiring diagram.
at first im trying to read the temperature from register 21 which is a temperature that has a offset of -300 regarding documentation.
Im using the TX0 and RX0 on the Arduino UNO wifi rev2.
I got this code:
#include <ModbusMaster.h>
ModbusMaster node;
Serial1.begin(9600);
node.begin(20, Serial1);
uint8_t result;
uint16_t rawTemperature;
float temperature;
result = node.readHoldingRegisters(21, 1);
if (result == node.ku8MBSuccess) {
rawTemperature = node.getResponseBuffer(0);
temperature = (float)rawTemperature / 10.0 - 300.0;
Serial.print("Temperature: ");
Serial.println(temperature);
I will also opload the data from the manufacture.
I will really appriciate if someone could point me in the right direction, as i cannot read anything in the serial monitor.
