Control Arduino over the internet
Hello all,
I'm interested in controlling my Arduino over the internet. I would like to put it in a different office and be able to control it over possibly a website or iPhone app. I have an Arduino UNO R3 and WifiShield.
Any ideas on how to go about doing this?
Thank in advance!!
Hi
There are dozens of examples & tutorials available online for how to do this (link to google search result). What is it you need the Arduino to do in response?
Cheers ! Geoff
Thanks for the answer!
Basically, I work on the front end of a software company. Our developers are in a different state, and we think it would be funny if whenever something went wrong, to set off a red light. So all the board would do is turn the light on/off.
Do you have any thoughts/suggestions on how i'd go about doing this?
Thanks!!
Use this example as it shows how to turn pins on and off over the internet.
http://bildr.org/2011/06/arduino-ethernet-pin-control/
I used this as the basis for a controller to turn lights and pumps on and off on my fishtank. I can do it from anywhere in the world as long as I have an internet connection. You will need to set up the arduino/ethernet shield combo as a webserver at the location where you will have the red "you screwed up" light. Connect it to a router and enable port fowarding on the router to route all port(??) requests to the ip address of the ethernet shield. I had a problem using Port(80) when I did mine because my ISP blocked it. I used port(150) and it worked fine. Just send commands over any web browser.
Must be a bit of a disappointment to the company, if you need to ask for help on such a simple project.
