Control blinds using nodemcu and amazon alexa
Hello Devs,
this is my first time on this forum and I hope I don't violate any rules. I have modified a piece of code to suit my needs i.e I want to control my curtains/blinds using nodemcu via my amazon Alexa. What I am trying to achieve through this code is that on giving the 'ON' command the stepper motor will move in one direction and then stop and on giving the 'OFF' command the stepper motor will move in the opposite direction and stop. I am not a programmer and hence cant verify if what I have done is right even though the Arduino ide says its right. Here is the code please verify if this will work or not. Thanks!
#include <Stepper.h>
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h>/releases
#include <ArduinoJson.h>
#include <StreamString.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
#define MyApiKey "" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "
" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "
**********" // TODO: Change to your Wifi network password
#define MYPIN1 14
int oneway; // counter for steps
int onerev = 6400; // number of steps each direction (edit this for your particular motor)
int microSecDelay = 30; // delay between steps and speed of the motor
// (about as fast as the system can react,
// higher number = slower)
int dirPin = 8; // output pin for stepper motor direction
int stepPin = 9; // output pin for the pin used to step the motor
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void setPowerStateOnServer(String deviceId, String value);
void setTargetTemperatureOnServer(String deviceId, String value, String scale);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
if (deviceId == "*********") // Device ID of first device
Serial.print("Turn on device id: ");
Serial.println(deviceId);
pinMode(dirPin, OUTPUT); // Assign output mode to pin for direction
pinMode(stepPin, OUTPUT); // Assign output mode to pin for setp
digitalWrite(dirPin, LOW); // Initialize dir pin
digitalWrite(stepPin, LOW); // Initialize step
delayMicroseconds(microSecDelay); // Wait microseconds
digitalWrite(dirPin, OUTPUT); // Initialize dir pin
digitalWrite(stepPin, OUTPUT); // Initialize step
else {
Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
if (deviceId == "*******") // Device ID of first device
Serial.print("Turn off Device ID: ");
digitalWrite(dirPin, HIGH); // Initialize dir pin
digitalWrite(stepPin, HIGH); // Initialize step
delayMicroseconds(microSecDelay) ;
else {
Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
// Example payloads
// For Switch or Light device types
// {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // Alexa.PowerController Interface 3 | Alexa Skills Kit
// For Light device type
// Look at the light example in github
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") { // Switch or Light
String value = json ["value"];
if(value == "ON") {
turnOn(deviceId);
turnOff(deviceId);
else if (action == "SetTargetTemperature") {
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.print("Connecting to Wifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
if(WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected. ");
Serial.print("IP address: ");
// server address, port and URL
webSocket.begin("iot.sinric.com", 80, "/");
// event handler
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization("apikey", MyApiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000); // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
webSocket.loop();
if(isConnected) {
uint64_t now = millis();
// Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
// If you are going to use a push button to on/off the switch manually, use this function to update the status on the server
// so it will reflect on Alexa app.
// eg: setPowerStateOnServer("deviceid", "ON")
void setPowerStateOnServer(String deviceId, String value) {
JsonObject& root = jsonBuffer.createObject();
root["deviceId"] = deviceId;
root["action"] = "setPowerState";
root["value"] = value;
StreamString databuf;
root.printTo(databuf);
webSocket.sendTXT(databuf);
//eg: setPowerStateOnServer("deviceid", "CELSIUS", "25.0")
void setTargetTemperatureOnServer(String deviceId, String value, String scale) {
root["action"] = "SetTargetTemperature";
JsonObject& valueObj = root.createNestedObject("value");
JsonObject& targetSetpoint = valueObj.createNestedObject("targetSetpoint");
targetSetpoint["value"] = value;
targetSetpoint["scale"] = scale;
