#include <GSM.h> // This includes the GSM library, included in your Arduino IDE
#define PINNUMBER "" // declaration of the constant PINNUMBER used to push the pin number of the SIM card
#define PIN 13 // declaration of the constant PIN, and setting it to output nr. 6
GSM gsmAccess; // opens up GSM access on the shield.
GSM_SMS sms;
char remoteNumber[20]; // Variable to store the remote number from the modem.
char c; //Variable for reading the sms messages from the SIM card
int x=0; //Counter for the number of SMS messages processed
char lastm; //Variable to stop SMS replying
String lastMess; //for storing the whole message
// **** 2 Setup ****
//Setup for SMS recieving. Serial setup makes it possible to monitor the status on your PC while connected
Serial.println("SMS Recieving");
boolean notConnected = true; // this defines a variable that indicates no GSM connection if true
while(notConnected) { // if there is no connection, the program runs gsmAcess. gsmAcess returns GSM_READY when connected
if(gsmAccess.begin(PINNUMBER"0462")==GSM_READY) // If you have a PIN number on your SIM card, write it as parameters here in quotes. PINNUMBER"9876"
notConnected = false;
else {
//messages printed on the serial monitor or LCD screen, then it tries again in 1000 milliseconds
Serial.println("No connection");
// if connection is established
Serial.println("GSM connected"); //GSM connected
Serial.println("Waiting"); //Waiting for SMS
// **** 3 The loop ****
if (lastMess == "H")
digitalWrite(13,HIGH);
else if (lastMess == "L")
digitalWrite(13,LOW);
//reading messages
if (sms.available()) // if there are SMS on the SIM card
x++; //message counter adds one
sms.remoteNumber(remoteNumber, 20);
//Show the message on monitor
Serial.println("Messages received from");
Serial.println(remoteNumber); //Prints senders number on the serial monitor
Serial.println("Message:");
while(c=sms.read()) {
String nextChar = String (c);
String Mess = (lastMess + nextChar);
lastMess = Mess;
/*sms.read collects one digit of the messages at time and stores it in the variable c.
This while loop builds a String variable "lastMess" from each byte in the messages for displaying.
Serial.println(lastMess); // prints the whole messages on the monitor and LCD screen
}//end for
sms.flush(); //discards the SMS message
I didn’t have any errors at the uploading but when i send the sms " H" , the sms received but pin13 didn’t go to high
What’s going wrong? here is the photo with the serial monitor http://postimg.org/image/v121wnhwr/
Finally with this code i managed to turn the led ON !
SMS receiver
This sketch, for the Arduino GSM shield, waits for a SMS message
and displays it through the Serial port.
Circuit:
* GSM shield attached to and Arduino
* SIM card that can receive SMS messages
created 25 Feb 2012
by Javier Zorzano / TD
This example is in the public domain.
http://arduino.cc/en/Tutorial/GSMExamplesReceiveSMS
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER "0462"
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
int led=13;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("SMS Messages Receiver");
pinMode(led,OUTPUT);
// connection state
// Start GSM connection
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.println("Waiting for messages");
char c;
// If there are any SMSs available()
Serial.println("Message received from:");
digitalWrite(led,HIGH);
// Get remote number
sms.remoteNumber(senderNumber, 20);
Serial.println(senderNumber);
// An example of message disposal
// Any messages starting with # should be discarded
if(sms.peek()=='#')
Serial.println("Discarded SMS");
sms.flush();
// Read message bytes and print them
while(c=sms.read())
Serial.print(c);
Serial.println("\nEND OF MESSAGE");
// Delete message from modem memory
sms.flush();
Serial.println("MESSAGE DELETED");
What changes i have to do in order to being able turning OFF the LED ?
Look at that code. What causes the LED to be turned on? Under what circumstances does that happen?
It has NOTHING to do with what is IN the message, so, there is lots more you need to do to make the LED come on correctly. When you understand that, it will be trivial to make the LED turn off correctly.
#define PINNUMBER "0462" // declaration of the constant PINNUMBER used to push the pin number of the SIM card
GSM_SMS sms;
if(gsmAccess.begin(PINNUMBER)==GSM_READY) // If you have a PIN number on your SIM card, write it as parameters here in quotes. PINNUMBER"9876"
else {
//reading messages
if (c == 'H')
else if (c == 'L')
lastMess = Mess;
}//end for
i managed when sending ‘H’ to turn on the led at pin 13 , but with very low brightness ,and when sending ‘L’ to turn off the led !
Why does this happen ,blinking the led with low brightness ? I measured 5 V at pin 13 ! do i need a stronger power supply ? i use a 12 V ,800 mA
