Control position of DC motor with encoder sweep
I am working on a project to control the rotation angle position of a DC motor shaft using a 3-phase encoder as a sensor. I want to control back and forth from -180 degrees to 180 degrees. And I'm building code like this using a PID controller. But the problem I encounter here is that my system is unstable and not following my wishes.
Please help me edit the chapter.
#define ENCA 2
#define ENCB 3
#define PWM 5
#define IN2 6
#define IN1 7
int pos = 0;
long prevT = 0;
float eprev = 0;
float eintegral = 0;
  pinMode(ENCA,INPUT);
  pinMode(ENCB,INPUT);
  attachInterrupt(digitalPinToInterrupt(ENCA),readEncoder,RISING);
  Serial.println("target pos");
  // set target position
  //int target = 1200;
 int target = 180*sin(prevT/1e6);
  // PID constants
  float kp = 1;
  float kd = 0.025;
  float ki = 0.01;
  // time difference
  long currT = micros();
  float deltaT = ((float) (currT - prevT))/( 1.0e6 );
  prevT = currT;
  // error
  int e = pos-target;
  // derivative
  float dedt = (e-eprev)/(deltaT);
  // integral
  eintegral = eintegral + e*deltaT;
  // control signal
  float u = kp*e + kd*dedt + ki*eintegral;
  // motor power
  float pwr = fabs(u);
  if( pwr > 30 ){
    pwr = 30;
  // motor direction
  int dir = 1;
  if(u<0){
    dir = -1;
  // signal the motor
  setMotor(dir,pwr,PWM,IN1,IN2);
  // store previous error
  eprev = e;
  Serial.print(target);
  Serial.print(" ");
  Serial.print(pos);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
  analogWrite(pwm,pwmVal);
  if(dir == 1){
    digitalWrite(in1,HIGH);
    digitalWrite(in2,LOW);
  else if(dir == -1){
    digitalWrite(in1,LOW);
    digitalWrite(in2,HIGH);
  else{
void readEncoder(){
  int b = digitalRead(ENCB);
  if(b > 0){
    pos++;
  else{
    pos--;
Access to pos has to be atomic, with interrupts disabled. Also pos should be flagged volatile.
  • Definitions do not match drawing.
  • pinMode for 5, 6, 7 not configured as OUTPUT.
Since pos is modified by an interrupt routine, it must be declared volatile, and it must be protected from modification by the ISR when accessed in the main code. Make and use a copy, for example as follows:
noInterrupts();
int pos_copy = pos;
interrupts();
Serial.println(pos_copy);
What type of output does your encoder have? Post a link to it's datasheet or product page or brand name and exact part number.
I used to encoder E6B2 CWZ1X
There's more to that part number, what is the pulses per revolution?
https://www.ia.omron.com/data_pdf/cat/e6b2-c_ds_e_6_3_csm491.pdf
The outputs are line driver.
1000 Pulses/round
What is the motor's rated voltage? What is it's rated full load and stall current? Which motor driver? Which Arduino?
I using Arduino Uno
